today> Twyndyllyngs Chez Mosc
Power supply?
Page 1 of 1 [15 Posts]
jamboard
PostPosted: Thu Nov 19, 2009 5:10 am    Post subject: Power supply?
Subject description: 12V DC -> -5V/0/5V DC
I need to generate -5V/0/5V for my synth project but I don't want to mess with 230V / transformers - indeed I want to build something small I can connect to one of the numerous 12V/500mA bricks I have around.
I need something like 150mA on the +5V rail (backlit display, a lot of LEDs + the audio circuitry), 50mA on the -5V rail (used only for the audio circuitry). Currently, I have a 7810 -> 2.2k/2.2k divider -> 741 -> BD135+BD136 push-pull (741 + push-pull replacing a high-output current op-amp), but I am not sure it is well suitable for the unbalanced load.
If you have already built something like that, your advice is appreciated! There are plenty of virtual ground circuits out there but I am just lost with all these options, none of them really matching my use case.
PostPosted: Thu Nov 19, 2009 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome jamboard.
Does the backlight have to be ground referenced? If not, the current could be better balanced ...
jamboard
PostPosted: Thu Nov 19, 2009 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good idea, if the backlight could be individually powered by the -5V/0V, this would shift ~50mA from the + rail to the - rail and balance the thing. But I'm using this:
http://www.sparkfun.com/commerce/product_info.php?products_id=813
which uses a common ground and supply for the back light, the controller, and the LCD itself. So the ground and +5V supply have to be the same as that of the microcontroller connected to the display (and pretty much all the digital section of the thing).
PostPosted: Thu Nov 19, 2009 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes, I see .. a smart backlight, nice thing in itself ... but the pulse width modulation in combination with a virtual ground may not be the best idea indeed.
Can't come up with a smart idea for avoiding a real double supply tho.
At least make sure to have some proper AC decoupling for the virtual ground to filter out the PWM stuff (to the + and - supply lines).
jamboard
PostPosted: Thu Nov 19, 2009 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a pair of 220uF / 100nF caps between the positive/negative rails and the virtual ground. Does that look reasonable?
I can think of one commercial synth which could have the same power requirements: the DSI Mopho (similarly looking LCD, powered by a 13-15V DC brick, not sure what's inside but say a micro and a bunch of CEM-like analog things...). How do they do it?
PostPosted: Thu Nov 19, 2009 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks reasonable, but would check with scope ... re. how they do it ... probably a switching power supply.
bod
PostPosted: Fri Nov 20, 2009 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
what about the ICL7660 (i think thats what its called), you could run 12v into that, create a -12v supply, regulate down to -5v with a 7905, and a 7805 for the +5v from the same 12v that was supplying the icl7660?
i've been using this for my cem3394 experiments and a variety of other things. the only issue with not regulating the negative supply, is that there is a slight voltage drop, so instead of -12v you get something like -11.6.
maybe there is a way round this though if any one knows?
spippoli
PostPosted: Fri Nov 20, 2009 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't know if a icl7660 would do, but anyway max1044 is a better chip. They're pin equivalent but with icl7660 you get a 10KHz ripple that will result in noise in the audio, while with max1044 (pins 1 and 8 bridged) the ripple is well out of audio frequencies
jamboard
PostPosted: Fri Nov 20, 2009 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Two questions about this switched capacitors thing:
- I checked the datasheet of several 7660 likes and they all work at 10kHz. Would this create an audible whine/buzz? If you have a scope, can you observe this? Do you know some equivalent of the 7660 with a higher switching frequency? The MAX1044 (a 7660 clone) has a "BOOST" pin to enable a faster switching frequency outside the audio range, but it's not available in a DIP package...
- What would be the respective advantages/disadvantages of:
* Getting -12V with a 7660 and regulating each branch with a simple 7x05.
* Getting +5V with a 7x05 and inverting it with a 7660?
jamboard
PostPosted: Fri Nov 20, 2009 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
That's exactly what I was looking at Smile Is the 1044 available in a DIP package?
jamboard
PostPosted: Fri Nov 20, 2009 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh, I think that would do:
http://uk.farnell.com/microchip/tc1044scpa/dc-dc-volt-converter-1044-dip8/dp/1196840
The datasheet answer my question... There's a voltage drop equivalent to a 70 Ohm resistance. Taking 50mA at 5V would cause a massive 3.5V drop, so it's better to get -12V first and regulate each rail.
So let's go for a 1044, and a pair of 7x05 on each rail. I'll compare this with the "virtual ground" approach, I have a found a cheap power op-amp that could be used for it: http://uk.farnell.com/jsp/search/productdetail.jsp?sku=1094203
bod
PostPosted: Fri Nov 20, 2009 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
i agree that you do get ripple noise with the icl, and it bugged me endlessly for many moons... however, theres a thread in the MFOS forum that covers this, and someone there, who's name escapes me, found that connecting pin one of the icl7660 to the positive supply worked and removed the noise, at least at audio levels!
it work for me as well with the ones i had bought from Rapid in the uk. a nice wee hack!!
jamboard
PostPosted: Fri Nov 20, 2009 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
On the MAX1044, the pin 1 (labelled "boost") is supposed to multiply the switching oscillator frequency by 6, moving it outside of the audio range. Maybe this is available on many other 7660 variants?
bod
PostPosted: Fri Nov 20, 2009 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-32855.html
thats the thread, i really made my day reading that and then trying it! i'm waiting on a new scope (if SWMBO takes a hint for my christmas poresent.... Wink ) to see just how bad it is, but i cant hear it any more, and i works fine for my sound lab and filter modules i've built recently. i'm going to take them down to my friends recording studio to see if we can pick anything up on highend recording equipment.
the data sheet for the icl7660a (the 12v model) shows pin one as no connection, but maybe these are all just the same chips with different branding and different datasheets?
they can only pump out 100ma, but thats enough for most of my projects and modules, and cheap enough to build into each one.
jamboard
PostPosted: Wed Nov 25, 2009 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks all, it worked perfectly with a 1044!
