Attack/Decay
Page 1 of 1 [3 Posts]
cranberrica
PostPosted: Mon Jun 22, 2020 10:32 pm    Post subject: Attack/Decay Reply with quote  Mark this post and the followings unread
Hi -
I'm sure most people here are familiar with this very simple circuit:
When you switch to "high", the first potentiometer gradually starts to glide towards the high signal. When you switch to low, the second potentiometer starts to glide towards the low signal.
I know there are more complex circuits for envelope generation out there - but I'm wondering if there is a way to trigger this envelope in a simple way. The only way I could imagine doing it was if the trigger impulse somehow opened a gate to a reference voltage that would be sent to a comparator and flipped to negative at the end of its excursion.
Anyone tried anything like this?
PostPosted: Tue Jun 23, 2020 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
an NE555 is very useful to do the things you mentioned. Here's an example:
more info here
or:
more info here
or:
more info here
gabbagabi
PostPosted: Wed Jun 24, 2020 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
or may u dont like 555 like me? Shocked Cool Smile
as the attached schemo uses a transistor for discharging the cap - u get a "better" decay
 Filesize:  20.06 KB
 Viewed:  309 Time(s)
