 Forum index » Clavia Nord Modular » G2 Patches - Completed » Acoustic
brass
matej
G2 patch files: 4
PostPosted: Thu Nov 08, 2007 10:58 am    Post subject: brass Reply with quote  Mark this post and the followings unread
I needed a brass section sound for playing with a band. We have trumpet and trombone, but when synth is added everything is fuller.
Part of the patch is borrowed from one of the G2 preset sounds.
I guess you could get similar sound with less DSP usage, but I was too lazy to do it.
It uses control pedal for volume and filter. In variation 6, morph group 6 is already copied to group 1, so you can use mod wheel instead.
Brass section 3v.pch2
 Filename:  Brass section 3v.pch2
 Filesize:  3.88 KB
 Downloaded:  2276 Time(s)
