trying to upgrade old schematics with ttl to cmos...
Page 1 of 1 [13 Posts]
loss1234
PostPosted: Wed Dec 19, 2007 6:32 am    Post subject: trying to upgrade old schematics with ttl to cmos... Reply with quote  Mark this post and the followings unread
I dont know much about this but i was wondering if i could use cmos instead of ttl for a few of these parts. i am going to try and build a "semi random" cv generator from an old schematic and it asks for lots of ttl. i wrote down what it asks for and also looked for substitutes based on my limited information (or disinformation)
any help appreciated!!
ttl ////// possible replacement?
7490-decade counter- 4017???
7441-bcd decoder- 4028???
74ls193-up down counter- 4029?
74154-4 to 16 decoder/demultiplexer-- no idea
74ls00-quad nand gate--- 4012 maybe?
74ls164-shift register-- 4015???
françois
PostPosted: Wed Dec 19, 2007 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello loss1234,
You certainly can redesign a TTL schematic to use CMOS instead, but you do have to redesign. Every (or so) TTL IC has a CMOS equivalent. But the pinouts are not the same, unused CMOS inputs must be grounded... I guess you already knew that.
Attached is a reference guide for finding equivalents. I can't remember where I found it, probably on Texas's site.
EDIT : the file is too big for an attachment (over 4Mbytes). You may find it at Texas's site, it is entitled "Digital Logic Pocket Databook". Sorry for that.
Yours,
-- françois
Digital Logic Pocket Databook (Texas).pdf
 Filename:  Digital Logic Pocket Databook (Texas).pdf
 Filesize:  4.68 MB
 Downloaded:  294 Time(s)
loss1234
PostPosted: Wed Dec 19, 2007 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i knew about the pinout differences..i figured i could attack some datasheets Smile
thanks for that awesome doc!!!
Pehr
PostPosted: Wed Dec 19, 2007 8:34 am    Post subject: Re: trying to upgrade old schematics with ttl to cmos... Reply with quote  Mark this post and the followings unread
4067?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
richardc64
Audio files: 26
PostPosted: Wed Dec 19, 2007 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
74C (which operates up to 15V but is getting harder to find) and 74HC (5V only) are pin-for-pin identical with TTL. Every TTL IC you listed should be available in 74HC somewhere -- even the '154.
The 7490 is a 4-bit decade counter: it has only 4 outputs. the 4017 decodes the 4-bit count into 10 discrete outputs -- which might eliminate the need for the 7441-bcd decoder. I'd have to see the circuit.
One thing to watch out for is the values of any pull-up and, to a lesser extent, pull-down resistors, which of necessity are lower values in TTL than in CMOS. One-shots and clock oscillators might need some tinkering of RC values.
loss1234
PostPosted: Wed Dec 19, 2007 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks like the 74ls164 is not any old shift register that i have in cmos. its an 8 out model. hmmm. i guess i need to save a tiny bit of money for shipping and make another big logic order.
etaoin
PostPosted: Thu Dec 20, 2007 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd opt for the easy option and replace all the 74LS by 74HCT which is readily available everywhere and fully compatible with TTL so most likely to work as a direct replacement without redesigning. Don't be fooled by the '74'. 74HCT is CMOS.
http://www.casia.org/modular/
loss1234
PostPosted: Thu Dec 20, 2007 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
ok then
i just need to order some of those chips!!
i always thought (incorrectly) that cmos had to start with a 4.
thnaks
etaoin
PostPosted: Thu Dec 20, 2007 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Note though that using HCT will give you the original circuit in cmos. I.e. it will still operate only at 5V!
PostPosted: Thu Dec 20, 2007 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 4000 series are metal gate CMOS devices and their propagation delays were very slow, on the order od 10's of nanoseconds. The 74HCT devices are also CMOS but much faster so higher performance designs could be done with them. the "H" stands or high speed. Now you get the high speed of bipolar devices and the low power of CMOS technology.
Some CMOS cores run at only 1.2 volts these days due to the small transistors on the die and to keep power dissipation to the lowest possible amount!
Virtually all digital IC's fabricated today are done in the CMOS process. So, years ago, yes, devices that began with the number "4" could only be CMOS digital IC's. Boy how times have changed Very Happy Very Happy
Bill
loss1234
PostPosted: Thu Dec 20, 2007 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
so 74hct are faster but can only run at 5 volts?
i like the 4000's because i dont have to run them at any odd voltage....
etaoin
PostPosted: Fri Dec 21, 2007 12:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, but keep in mind that running a circuit at different voltages will most likely mean redesigning it at least partly. Just changing the ICs won't work.
fluxmonkey
PostPosted: Fri Dec 21, 2007 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
nice overview of various logic families of chips:
http://www.interfacebus.com/Design_Logic_Family_Selection.html
also links to handy charts outlining various trigger voltage levels, if you wind up needing to mix families.
b
