sect chks error ready for update
Page 1 of 1 [4 Posts]
Jack_Hertz
Audio files: 101
G2 patch files: 7
PostPosted: Thu Jan 15, 2015 10:27 am    Post subject: sect chks error ready for update Reply with quote  Mark this post and the followings unread
Got this message on my G2 today. Anyone know what it means and if there is a fix for this?
Jack Hertz.com | Aural Films
Jack_Hertz
Audio files: 101
G2 patch files: 7
PostPosted: Thu Jan 15, 2015 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE: I thought it might be the Encore expansion card. Opened up the G2 and reseated the board. No change.
Next I tried reloading the OS 1.62 and it has restored the G2 to its working state with original patches and all. So all is not lost. Smile
Would like to know what that error means if anyone knows.
Audio files: 305
PostPosted: Thu Jan 15, 2015 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
No idea really ... can guess sector check error, which would be flash memory related then probably ...
varice
Audio files: 29
G2 patch files: 54
PostPosted: Thu Jan 15, 2015 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
An internet search on “sect chks error” (short for sector checksum error, apparently) found a few results related to Nord keyboards. One is a forum page (in French) where a person got this error on a Nord Stage and then could not run the OS update:
http://www.laboitenoiredumusicien.com/forum/topic-7320.html
The final update was this post (translated to English):
porlair wrote:
To close this subject, I wrote clavia who advised me to contact the customer service.
So I turned my keyboard where I bought it. The repairman called me today to tell me that it comes from the motherboard (500 € HT) and more precisely from the memory of the motherboard. But as Clavia provides no pattern to resellers, we must change everything.
In short, it is a relatively rare crash as clavia provides very good material .... and it falls on moi.
Required a motherboard replacement for 500 €? OUCH Exclamation
I’m not sure that would be necessary though. If the error is from a socket mounted memory chip, simply popping in a new chip should at least get you back to square one.
So Jack, it appears that you were lucky enough that your G2 was at least able to allow the OS update to run. But, as always, I recommend that you keep a current backup of your patches just in case…
varice
