today> Twyndyllyngs Chez Mosc
 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
nomad on SnowLeopard, micro modular, bad issues feedback
Page 1 of 1 [2 Posts]
mihozu
PostPosted: Thu May 12, 2011 3:53 pm    Post subject: nomad on SnowLeopard, micro modular, bad issues feedback Reply with quote  Mark this post and the followings unread
Hi there,
Just a quick word to give feedback about nomad on OsX Snow Leopard.
After struggling for a while everything finally works.
Some information about my system :
Micro modular with updated 3.03 os and put in external clock mode with the clavia editor
Os 10.6.7
updated Java 13.4.0
M-Audio Midisport 2x2
nomad 1.0
libosxmidispi.jnilib
osxmidispi.jar
both provided with nomad
It strangely works only with the "A" port of the midisport 2x2 (communication timeout with "B" port).
Thanks a lot for development!
mihozu
PostPosted: Fri May 13, 2011 7:04 am    Post subject: more feedback on nomad on SnowLeopard Reply with quote  Mark this post and the followings unread
Ok now some more feedback about nomad on Osx SnowLeopard.
When click-&-dropping a patch tab on the left down synth area i loose connection most of time. Is it due to the midisport 2x2 interface?
I have same issue with the nomad.jar on windows xp.
The other problem I encountered is with the morph knob behaviour.
The modulation is going opposite with the morph range defined : ie a morph is defined on [0,A] interval and when turning the morph knob the modulation goes 'value-A'.
I don't have this issue on winXp.
