 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Hanging synthesizer + sequencer issues
Page 1 of 1 [3 Posts]
PostPosted: Sun Mar 16, 2008 8:19 am    Post subject: Hanging synthesizer + sequencer issues Reply with quote  Mark this post and the followings unread
Was messing about with Nomad just now, and as I worked with this sequencer patch, I added a filter and an env module and noticed that the sequencer wasn't updating anymore. I tried "Save in synth", but I got some error (or no response). Looking down on my NM Key, I tried changing to another slot, but nothing happened. I tried turning the jog dial, or go into the system menu - nothing! I had to turn off the synth and then turn it on again to get stuff working.
Two minor things on the note sequencer - it doesn't show the note values as you edit them. Also, the led indicator seems to be lagging behind one step, compared to what I'm hearing. Check the attached patch to see if you get the same behaviour.
I'm running on OSX 10.4.11, my Nomad was installed 2008-03-10.
/Stefan
shape_sequence.pch
 Filename:  shape_sequence.pch
 Filesize:  1.1 KB
 Downloaded:  540 Time(s)
chresan
PostPosted: Sun Mar 16, 2008 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Stephan,
thanks for the feedback, this is very appreciated. I will take a look what is going wrong.
The behavior of the lights can be wrong depending on the patch. As for the lockups of the synthesizer - this can happen in different situations. It is annoying but it won't damage your synthesizer. We are working on these problems and hopefully they are fixed in the next release.
Christian
http://nmedit.sf.net
nathan
PostPosted: Sun Mar 16, 2008 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have the same thing in different patches.
-led in sequencers not running correctly
-indeed notevalues not shown in notesequencer
plus,
-turning of assigned knobs on synth itself doesnt work correctly (jams)
-sudden freezes
- no saving into synth possible
