today> Twyndyllyngs Chez Mosc
TDA1022 alternatives ???
Page 1 of 1 [6 Posts]
3vcos
PostPosted: Sat Oct 20, 2007 1:23 pm    Post subject: TDA1022 alternatives ??? Reply with quote  Mark this post and the followings unread
Anyone know of a substitute for the TDA1022 bbd delay chip? Seems there has been a run on them since JH announced his board and there isn't much stock anywhere! Do any of the panasonic chips work for this application?
JuergenPB
PostPosted: Tue Oct 30, 2007 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
MN3004 or MN3010 might be replacement. But first check the datasheets.
or MN3210 -- it is a dual 512 stage BBD
StephenGiles
PostPosted: Tue Oct 30, 2007 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
But they won't be drop in replacements.
PmCimini
PostPosted: Mon Apr 07, 2008 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there ANY way to fit a MN3007/MN3207 in the place of a TDA1022 even though the number of cycles is different? can you accomplish that with some circuit changes in the clock and some other changes because they act differently with the input signal? Thanks
23isgood
PostPosted: Tue Apr 08, 2008 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mr. Tom Arnold has some TDA's. You can try contacting him to see if he can sell you some,
Check out my music
PmCimini
PostPosted: Tue Apr 08, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can get the TDA's (not at a cheap price, though) but i just wanted to know if its possible to make a 512 stage circuit with a 1024 stage bbd, and if i have to make lots of changes to switch the IC's...
