 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Error connecting
Page 1 of 1 [21 Posts]
squarewhite
PostPosted: Thu Mar 13, 2008 5:02 am    Post subject: Error connecting Reply with quote  Mark this post and the followings unread
Hallo All,
having heard about this new open source editor for nm, i decided to download and install. I've also downloaded Plumstone for osx on ppc. without the plumstone nomad doesn't seem to even see my midi interfaces. but with plumstone, in connect/disconnect under nomad, it 'sees' my interfaces but when i apply, it spit out an error.
here it is
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1205408622373 [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1205408622373 [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmProtocol.heartbeatImpl(NmProtocol.java:5Cool
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular$SchedulingProtocol.heartbeatImpl(NordModular.java:252)
at net.sf.nmedit.jnmprotocol2.AbstractNmProtocol.heartbeat(AbstractNmProtocol.java:154)
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:114)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:358)
... 10 more
what should i do?
osx 10.4.10, nm keys, ibook g4 ppc
thanks
squarewhite
PostPosted: Thu Mar 13, 2008 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, midi interface for nm data transfer - midiman midisport 2x2
for normal midi notes transfer - motu midi express
squarewhite
PostPosted: Thu Mar 13, 2008 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
ah the coffee is not strong enough.
i've assign input and output on port a in/out on the midisport. then i get this error,
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=Port A (MidiIN:1),vendor=M-Audio,description=Midi IN port:1] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=Real Time Sequencer,vendor=Sun Microsystems,description=Software sequencer]].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:248)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
at java.awt.Dialog$1.run(Dialog.java:535)
at java.awt.Dialog$2.run(Dialog.java:563)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Dialog.java:561)
at java.awt.Component.show(Component.java:1302)
at java.awt.Component.setVisible(Component.java:1255)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$2.actionPerformed(SynthObjectForm.java:609)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:5583)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
at java.awt.Component.processEvent(Component.java:5348)
at java.awt.Container.processEvent(Container.java:2010)
at java.awt.Component.dispatchEventImpl(Component.java:4050)
at java.awt.Container.dispatchEventImpl(Container.java:2068)
at java.awt.Component.dispatchEvent(Component.java:3885)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
at java.awt.Container.dispatchEventImpl(Container.java:2054)
at java.awt.Window.dispatchEventImpl(Window.java:1791)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
wesen
PostPosted: Thu Mar 13, 2008 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
That real time sequencer error seems to show up with plumstone/mandolane very often. Either try the latest mmj (it should be 0.85 i think), or osxmidispi. Regarding the interfaces not recognized with osxmidispi, I'llhave a look. Sorry for all the midi troubles, this is quite a tricky area (despite it sounding so easy)...
Audio files: 309
PostPosted: Thu Mar 13, 2008 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
But you seem to have almost perfect compatibility now with the original Clavia editor Wink
squarewhite
PostPosted: Thu Mar 13, 2008 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
mmj is at 0.84. using either mmj or the oxsmidispi still doesn't show up my midi interface. only with plumstone but then same error. always at one time it's either mmj or osxmidispi or plumstone in my java/extensions
human.koala
PostPosted: Thu Mar 13, 2008 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
first thanks to save our g1 modular ;o)
the new editor rules !!
i have the same problem here
micromodular
Os X 10.4.1
Presonus firepod for pc in/out
unable to see my midi ports with mmj & oxsmidispi
and with plumstone error while trying to connect to the modular
i will send the error log later if it could help
thanx ;o)
HK
http://www.humankoala.com
wesen
PostPosted: Thu Mar 13, 2008 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok I think I am filtering out ports with only 1 endpoint in my osxmidispi, and mmj seems to do the same. I will check this when I have some time this weekend. Sorry to keep you waiting folks.
human.koala
PostPosted: Thu Mar 13, 2008 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
panipwoblem,
thanx for all this work ;o)
HK
squarewhite
PostPosted: Thu Mar 20, 2008 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
any help yet?
gomidas
G2 patch files: 6
PostPosted: Sat Mar 22, 2008 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
The platform independent works for me http://downloads.sourceforge.net/nmedit/nomad-0-3_2.zip?use_mirror=osdn
Hope it helps?
squarewhite
PostPosted: Thu Mar 27, 2008 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
hi,
thanks for the link.
well i've click on the nomad.jar file. it opens up but still the connect and disconnect error appears.
i forgot the mention that i'm on
ibook g4 1,33ghz 1,2 gb rams, nord modular keys, midiman midisport 2x2 connected to pc ports
i could post the error messages if needed.
what else? which java version do i need?
gomidas
G2 patch files: 6
PostPosted: Thu Mar 27, 2008 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Connection Timeout?...Did you try to change the midi clock to "EXT" in the NM Keyboard?
You need java 5 (1.5) or 6 (1.6)
Goog luck
onebigdoor
PostPosted: Thu Mar 27, 2008 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
having similar issues.
on os 10.5 PPC G5
the osxmidispi gives me no options on the connections page
plumstone gives me an error when i hit apply
and mmj gives me all of my midi ports and doesn't give an error when i apply, but all settings on settings page are greyed out, and i still don't seem connected.
gomidas
G2 patch files: 6
PostPosted: Fri Mar 28, 2008 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
on os 10.5 PPC G5
and did you try mandolane?
http://www.mandolane.co.uk/swMandoMidi.html
onebigdoor
PostPosted: Fri Mar 28, 2008 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the reply, i can't wait to get this working. it's very exciting.
yes, i tried mandolane and had the same result as plumstone.
i should add that i'm using a motu fastlane as an interface, and the osx editor from clavia works (with it's bugs, of course)
squarewhite
PostPosted: Fri Mar 28, 2008 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
yes it's a good software compared to the osx editor for the nord.
but it doesn't work.. such a pity.
i've upgraded my java to 6. tried plumstone, or mmj, but still no luck. what else could one have over look?
julien
PostPosted: Mon Mar 31, 2008 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello did you try the OSX midi implementation ? The one delivered by the project ?
squarewhite
PostPosted: Mon Mar 31, 2008 1:05 am    Post subject: Reply with quote  Mark this post and the followings unread
hi yes, I've tried java osx midi implementation witth the nomad version 0.32 (platform independent) and the osx verison. both doesn't show my midi devices. only with plumstone that i see my midi devices, but failure connecting with the nord modular.
here is the error message with plumstone
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=Port B (MidiIN:2),vendor=M-Audio,description=Midi IN port:2] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=Real Time Sequencer,vendor=Sun Microsystems,description=Software sequencer]].
squarewhite
PostPosted: Mon Mar 31, 2008 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
what does this mean?
could it be that java doesn't recognise the midisport?
i could try on my motu micro express and get back with results.
just to be sure the connection with the ports labeled PC from Nord modular, right? that's the only way data info can be sent.
regards
d
julien
PostPosted: Mon Mar 31, 2008 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes you have to plug in the PC port on the nord.
Did you install the last version of Java and Plumstone ? You can also give a try to your other interface.
