Digitzer module rumble?
Page 1 of 1 [6 Posts]
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun May 04, 2008 12:44 pm    Post subject: Digitzer module rumble? Reply with quote  Mark this post and the followings unread
I don't know if this is a bug or not, but the digitizer seems to introduce something in here that then drives the pitch shifters.
hit run at 132BPM, then hit stop. then notice the rumble. It is definitely introduced by the digitizer, but this does not sound right to me.
The funny thing is if you move the druym synth level knob (the morphed one), below a certain level, there is no rumble but if you go beyond midway, rumble when clock stopped.
Your thoughts? Can you reproduce it? It happens in both the G2 demo and real thing.
/Dasz
 Filesize:  145.94 KB
 Viewed:  981 Time(s)
LG2 DrumTemplate Bug.pch2
 Filename:  LG2 DrumTemplate Bug.pch2
 Filesize:  2.76 KB
 Downloaded:  1982 Time(s)
Audio files: 309
PostPosted: Sun May 04, 2008 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, you dont need the digitizer ... the problem seems to be the the drum synth actally, it's not completely shutting off it seems but it needs the pitch shifter and a lot of amplification to make that audible .. when you toggle the mute button of the drum synth the effect comes and goes ... when you add a noise gate after the drum synth the problem is solved. Erm, I tried this in the demo Wink
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun May 04, 2008 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, Jan. I am not crazy Wink
/Dasz
Audio files: 309
PostPosted: Sun May 04, 2008 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
dasz wrote:
I am not crazy Wink
Absolutely not Exclamation
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun May 04, 2008 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, Jan Wink
/Dasz
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue May 27, 2008 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
i really love that noise gate.. can't do without Very Happy
