TwinT with CMOS inverter For Electronic Drums
Page 1 of 1 [4 Posts]
redbuttonplayer
PostPosted: Thu Apr 01, 2021 5:07 am    Post subject: TwinT with CMOS inverter For Electronic Drums Reply with quote  Mark this post and the followings unread
I'm trying to make a drums module based on a twit t oscillator that using a CD40106 (trigger di Schmitt)
To do that I started from an article found in an old electronic magazine. My custom schema it's very similar to the attachment.
There is only one difference with original schema: I use an inverter Schmitt's trigger instead of a nand configured like an inverter.
Also I add a potenziometer between r5 and p1 to have more control about release.
When I check my circuit the oscillator enters in an infinite oscillation.
What is the problem? Could be logic port type? Anyone can give me anything to solve this problem?
Thank you in advance
R and C Values are specific for low bongo
 Filesize:  7.55 MB
 Viewed:  220 Time(s)
PostPosted: Thu Apr 01, 2021 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
a schmitt trigger inverter will not work for this and you most likely need an unbuffered chip like the CD4069UBE
but a CD4049 might work too.
redbuttonplayer
PostPosted: Thu Apr 01, 2021 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you so much @PHOBoS for your feedback
I suspected that. But your response gives me a confirmation.
I'll try with one of chips that you suggest to me.
Maybe you know any inverter chip with a socket more similar to cd40106? (unfortunately it's a little bit different)
redbuttonplayer
PostPosted: Thu Apr 01, 2021 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, i mistake with cd4049, cd4069 has the same socket
