OSX editor frustration
Page 1 of 1 [12 Posts]
shavers
PostPosted: Sat Jul 31, 2004 3:52 am    Post subject: OSX editor frustration Reply with quote  Mark this post and the followings unread
Finally got my G2 only to find that the version of OSX on my dual boot powerbook [v10.1] wont open the installer!!
It's an old OS but I wanted to use this old laptop solely as the G2's editor.
I know it's a bit off topic but do any mac users know where I can pick up a newer version of osx for cheap/free? Any suggestions?
Also, how would I go about installing this as one of the OSs on a dual boot system?
cheers, s.
p.s. dope site
Audio files: 232
PostPosted: Sat Jul 31, 2004 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome to electro-music.com, Shavers.
I don't know where to get OSX releases. Just wanted to say hi...
PostPosted: Sat Jul 31, 2004 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Well.. unless you pay for the current retail version ( 10.3.4 ), you will have to turn to piracy using bittorrent ot whatever.
Dual boot? As in 2 partitions and different OSes on each partition.. or do you mean that X/Classic install..
If you have 10.1 on that box.. you really should go 10.3.4
recommended
Flickr
paul e.
PostPosted: Sat Jul 31, 2004 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
yes the 10.1/9.2.2 combo needs to be updated...10.1 is not supported well by 3rd party manufacturers
Spiral Recordings
3phase
G2 patch files: 141
PostPosted: Sat Jul 31, 2004 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
10.1 sucks, up from 10.23 it started working, so if you dont want to go to panther (10.3+) you should at least update to 10.28
On my machine ( a 1gigaHz Titanium) panther is much faster than yaguar..
Tiger is coming soon...but i am not sure if a fat tiger will be good for older macs...
we will see
3phase
G2 patch files: 141
PostPosted: Sat Jul 31, 2004 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Certain updaters are on the apple side www.apple.com
But they dont offer the main installers there you need a 10.2 or 10.3 installer disk and than you use the updaters from the apple side...
For your system you only find an update to 10.15 on the apple side...probably not enough
Copys of installers from your neighbours usually do the job if its a general installer and not a modellspecific one.
Installing on a dualboot system can cause troubles...depends a bit on the configuration.
Safest thing is like allways to have a clean install...wiped harddisk, than OSX...afterwards the os9 install...
If you really just want to run the editor, a plain osx update probably does the job...
PostPosted: Sat Jul 31, 2004 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Well.. you will need the 10.2 or 10.3 CD sets. Alternatively, you can "get" the same.. in the form of .dmg, .toast or other kinds of image files. If you get these.. then you can burn your own set. It is not possible to install from the image files even if these are mounted. Do not even try. Generally, you can risk "hurting" the image files if you mount them.. so mounting is absolutely uncool. You may end up with unbootable disks and will have to download these one more time.
Of course.. if you have a buddy who makes a .dmg... bootable.. of a partition with 10.3.x .. you can use a wide range of tools in order to transfer the contents of this .dmg file to your machine. Warning...! If you do not know what you are doing... then don´t.
There are many options really... you can even do network installation from a file on an http or ftp server. ..but in essence.. this is not something you should mess around with unless you are very into these things.
Dragging the visible files system files to a disk will not leave you with a working OS X system.
I recommend buying the 10.3 set.
Flickr
PostPosted: Sat Jul 31, 2004 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
The 10.2 and 10.3 installers will leave you with a universal OS X system which will boot and run most OS X compatible Apple computers.
Flickr
shavers
PostPosted: Mon Aug 02, 2004 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey,
Thanks for the welcome and the advice!
Yes, by dual boot I did mean osx/os9 on seperate partitions : selectable os/startup disk.
Would love to do a complete fresh install of panther/tiger(when it's available), but I still need to run OS9 on one partition of this powerbook (over 2000 Supercollider 2 patches that I still use).
I bought an ibook recently, so I can run the G2 editor in the meantime but it would be better with that 15" screen.
thanks again, s.
PostPosted: Mon Aug 02, 2004 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok.. I see. Well.. I kinda do the same. I still use Cubase 5.2 VST32. Very very smart to run OS 9.2.2 from a clean partition.
Flickr
shavers
PostPosted: Mon Aug 02, 2004 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Elektro80.
You mentioned that these dmg files might be sitting on a ftp server. Is there one you could point me to? Limewire is quite dicey for this sort of thing - Lots of versions of the same file, but all different sizes!
I reckon I can justify this temporary solution as I'll get a multiple license for Tiger somewhere down the line. And like I said, it's only to run the G2 editor.
Sorry for going way off topic with this, s.
PostPosted: Mon Aug 02, 2004 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes... well.. or an NFS volume or over HTTP. But.. sorry.. the only stuff I have up are my network install images here at work. For obvious reasons I cannot share their location and login info. Installing over http ... approx 2.8 gig.. is not that fun really.. I run a gigbit ethernet here.. but I do not have a gigabit internet connection.. Very Happy
And.. the licensing.. you know.. Very Happy
Flickr
