A beginers guide to building a synth
Page 1 of 2 [28 Posts]
dbtraktion
PostPosted: Fri Nov 14, 2008 9:31 am    Post subject: A beginers guide to building a synth Reply with quote  Mark this post and the followings unread
Well ive just signed up to the forum in the hope i mite be able to start building my first synth.
There is so many sub forums that im not sure where i should of posted this so i thought here mite be ok.
Can anyone link me to a post(s) or any websites, or even books that are aimed at a complete novice. I need to learn everything from scratch.
Audio files: 299
PostPosted: Fri Nov 14, 2008 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome
I'll move your post a level up to the general section, it's a bit hidden behind all the sub-forums Rolling Eyes
As an absolute beginner you'll maybe not have an idea as to what to build, but do you maybe have a type of music you are aiming for? Any other instruments that you are playing? Or maybe your primary interest is in electronics?
joshco
PostPosted: Fri Nov 14, 2008 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello,
for the beginning i would suggest the atari punk console. the parts are easy to get and you can learn how to use the solder iron etc.
http://www.getlofi.com/?p=518
from MFOS soundlab mini are some kits available. try to get a complete kit and depending on your hardware skills, a suitable case...
its more complex and maybe too much for starting.
what have you planned to build
a modular synth or synth in general?
regards!
[/url]
dbtraktion
PostPosted: Fri Nov 14, 2008 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome
Hi and cheers
Well i make lots of electronic music, I have various synths and and hardware. The type of synth im aiming to 4 to begin with i would hope to build a genral synth with and an osc' or 2, with envelopes, and filters etc. Is this to much for a first synth?
I work for a audio cabling company so i have some knowledge of electronics and have plenty of expierence soldering.
BobTheDog
PostPosted: Fri Nov 14, 2008 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I have been thinking the same thing myself.
Have you had a look at http://www.musicfromouterspace.com/ specifically http://www.musicfromouterspace.com/analogsynth/SOUNDLABMINISYNTH/soundlab.html
Andy
Audio files: 299
In that case I'll say the same thing joshco did, soundlab , lots of people here built it so you could expect some help when you get stuck and it will give you a good idea what it's all about.
BobTheDog
PostPosted: Fri Nov 14, 2008 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
snap Wink
dbtraktion
PostPosted: Fri Nov 14, 2008 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok thanks for the replys so far so they have been really helpfull...
would this be the right kit 'Sound Lab Mini-Synth Component Kit (w/PCB)', this would be found with a paypal option beside it?
So you get the kit, all parts etc, apart from the housing ?
Is it difficult?
Sound
PostPosted: Fri Nov 14, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
dbtraktion, you have found the right place : this forum. Very Happy
Why not start a modular synthesizer? Here is how I did two filters of Fonik. http://www.electro-music.com/forum/topic-19166.html
http://www.modular.fonik.de/
Also you have www.magsmoke.com where you can found PCB for the mankato, 566 Oscilator, and the TH 21st Century LFO and very interesting and highly recommendable books of Thomas Henry. http://www.electro-music.com/forum/forum-148.html
Or maybe you would like start with a drum machine?
http://www.electro-music.com/forum/topic-28509.html
Tim Servo
PostPosted: Fri Nov 14, 2008 1:46 pm    Post subject: A beginers guide to building a synth Reply with quote  Mark this post and the followings unread
Hi DB,
I would highly recommend some basic electronics material. Not all of this is related to audio or music, but it will be a great way to learn electronics. Also, you might be surprised to learn how many of these basic circuits turn up again and again in synthesizers. I'd start with the Radio Shack "Learning Lab," or at least download the User's Guides (two PDFs, about halfway down the page) and read through them. If you don't get the Radio Shack gizmo, I'd still recommend getting a "breadboard," some wire and a few basic parts to play with. You'll also want a good multimeter and soldering iron. Eventually you'll want an oscilloscope, but you won't need one just to start out.
For a first project, I'd recommend the Ray Wilson WSG. I think the SoundLab might be a bit much for a beginner (especially with all the panel wires).
Welcome to the forum, and to the Synth DIY addiction! Smile
Tim (bigger than a breadboard... or is that bread box?) Servo
Tim Servo
PostPosted: Fri Nov 14, 2008 1:48 pm    Post subject: A beginers guide to building a synth Reply with quote  Mark this post and the followings unread
Oh, and here's the link to that Radio Shack gizmo, and the User's Guides (written by the very popular Forest Mimms):
http://www.radioshack.com/product/index.jsp?productId=2102913&tab=support
Cheers!
Tim (semi-popular) Servo
joshco
PostPosted: Fri Nov 14, 2008 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it difficult?
For the case you can use a wooden box or something. The Pcb from Ray Wilson are very good. If it´s difficult depends on your knowledge.
You should know the parts, especially IC´s, very well.
The Projects from this site are very well documented and here are lot of people who know very much.
Just work patiently and cacarefully, but be warned all this diy stuff is addictive Very Happy
dbtraktion
PostPosted: Sat Nov 15, 2008 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
hello guys
These links are very helpful. im checking them out. I'm sure if i have any question u'll b able to oblige Smile
If anyone wants to add any more info please do.
One question to start with though is:
You buy a kit, you get all components such as pcb, resistors, etc, but these kits dont include housing or face boards, and rotary caps etc no? Are there are any kits that do?
Pehr
PostPosted: Sat Nov 15, 2008 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.elby-designs.com/synth-modules/soundlab/soundlab.htm
http://www.elby-designs.com/shopping/index.html?lang=en-uk&target=d6.html
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
dbtraktion
PostPosted: Sat Nov 15, 2008 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone know if there are any good videos any where to help me get started, perhaps learnth basics. Using a breadboard and components sounds like a good idea, help me get on the ladder?
I found this video:
http://uk.youtube.com/watch?v=ofq1EzbJxfI&NR=1
Problem is they're in random videos, and not in episodes so i have no idea what order watch them.
Dave Kendall
PostPosted: Sat Nov 15, 2008 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
Something that really helped me out when I started was simply studying the schematics on the CGS site
Like the MFOS site, the information and particularly the schematics are well laid out, and there are some great wiring diagrams. Simple modules like this one show circuits that often turn up in all-sorts of synth modules.
Some of the designs are pretty complicated, but similar sub-circuits show up again and again. (I used to study them, and others gleaned from the net during a long daily train commute.)
Some other sites for synth DIY that may be of interest:
http://www.bridechamber.com/bridechamber.com/Home.html - pcbs for sale, and it includes links to some others, including;
http://www.yusynth.net/
http://home.comcast.net/~ijfritz/
http://home.debitel.net/user/jhaible/hj.html
some other good ones...
http://www.uni-bonn.de/~uzs159/
http://home.comcast.net/~sbernardi/elec/og2/sitemap.html
http://m.bareille.free.fr/synth.htm (PCBS available)
http://www.ucapps.de/ for midi stuff - some PCBs available indirectly through their forum.
And finally, http://www.introspectiv.org/ an advanced build but *very nice*.
I hope to build my board this xmas break.
http://www.subatomicglue.com/9090l0g/ has some very good build details, and Trevor Page of introspectiv is currently gauging interest for another run of PC boards.
Hope that helps Smile
Dave Kendall
PostPosted: Sat Nov 15, 2008 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
some others....
http://home1.gte.net/res0658s/fatman/
The fatman comes as a complete kit with a MIDI interface, which is very useful if you have a computer and hardware rig, and it can be modded lots.
http://mypeoplepc.com/members/scottnoanh/
http://www.curetronic.com/curetrbau/neubau/bau.htm
http://www.tellun.com/motm/diy/diy.html
there are others out there too, but I've just been invited up to the pub, so the computer is being switched off now Very Happy
(edited for typos)
LektroiD
PostPosted: Sat Nov 15, 2008 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Soldering tips here:
http://uk.youtube.com/watch?v=3dkragEKSKI&feature=related
Pretty basic video, but worth watching, here's a couple of my own tips that I've picked up over the years which were not mentioned in the video...
Rather than bending the legs over to hold the components in place like the video suggests, what I do is to populate the board in levels, starting with the components that have the smallest physical height / protrusions, placing a flat piece of wood just marginally bigger than the board over the top of the components to hold them in place before turning over, starting with wire links first, then diodes, resistors, smaller ceramics, IC sockets, transistors, electroylitics etc... By the time you come to soldering the larger components, you can use mostly your fingers to hold them in place while soldering. There are proper clamps designed for 'through hole' soldering in the industry, but for the amount of soldering you'll do, the piece of wood technique will suffice.
Always pre-bend component legs to fit the correct pitch (hole spacing) with a pair of pliers, especially smaller components, such as wire links, diodes & resistors. A a fully populated board that's clean looking makes troubleshooting a lot easier.
Get in the habit of facing your non polarised components the same way, such as resistors (always have the tolerance band at the same end). It makes it easier to read when it comes to troubleshooting.
Here's my MFOS WSG for an example: (also included a photo of the front panel while I'm at it)...
Stripboard layout
 Filesize:  212.53 KB
 Viewed:  174 Time(s)
Front (without pot caps)
 Filesize:  134.39 KB
 Viewed:  154 Time(s)
dbtraktion
PostPosted: Sat Nov 15, 2008 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers brainstormer
Nice pics, ur neatness and attention to detal are definatley something i would aim for and to do myself.
I have some experience of soldering. I work for an audio cable company, so i solder jacks, rca's and bfa's etc to cable.
dbtraktion
PostPosted: Sun Nov 16, 2008 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
So...
I think the best way for me to build my knowledge is by getting a breadboard and components.
What do i need? I would like to get as many components as i can to start simple but build to more complex stuff and experiment with.
Maybe something like this:
http://uk.youtube.com/watch?v=VED1swbg8Xs
But maybe have more possiblities such as modulation and more osc's.
Cheers Smile
Edit: Perhaps like this??
http://uk.youtube.com/watch?v=p0xdrycD680
LektroiD
PostPosted: Sun Nov 16, 2008 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
some simple breadboard projects to get you started here:
http://www.play-hookey.com/digital/experiments/rtl_bistable.html
Get yourself a cheap oscilloscope from ebay. Then try changing the values of the components to see what it does to the results. Experiment with it so you get a feel of how the current flows, and what all the components do.
dbtraktion
PostPosted: Mon Nov 17, 2008 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Could i use an oscilloscope vst plugin?
Can anyone give me a list of components to get with a breadboard to start building?
numbertalk
PostPosted: Mon Nov 17, 2008 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
There are also projects you can build that don't require a scope to calibrate, if you want to hold off on that. I've been warned against buying scopes from ebay as far as whether or not they're calibrated or what kind of shape they're in. Not sure if you could use a strictly software-based scope - have never tried.
dbtraktion
PostPosted: Mon Nov 17, 2008 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Would this be hard to do just using components and a breadboard?
http://uk.youtube.com/watch?v=t8M9Lg2Cl5w
PostPosted: Mon Nov 17, 2008 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
i can tell you strories... i recently bought a few scopes!
the 1st came from overseas and was damaged during it's journey across the ocean, sending it back was not worth the postage.
the 2nd one was an old vintage scope, AC coupled. looks quite nice, though.
the 3rd was damaged by post, too: the whole housing was into pieces. you could have used the package as outsized rattle.
the 4th is quite nice and from ebay. fortunately the sellers was on a business travel in my region anyway, and he just dropped by to hand it over.
