 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Polyfonic Unison Leads
Page 1 of 1 [2 Posts]
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Mon Dec 29, 2008 4:08 pm    Post subject:  Polyfonic Unison Leads Reply with quote  Mark this post and the followings unread
This is actually a performance, but it should be 1 patch... It's made for Expanded G2's and G2X. If the voices are too low, the variations will sound different and less characteristic.
After a couple failed attempts i made this one stable enough for everyone. On heavy detune the sound bounces the pitch when you press the same key again. I hope any of you can figure out how to solve that problem. I've made the variations in bound with no bouncy pitches. So this version1 is completed.
variations:
V1: Uni Lead
V2: 7th Lead
V3: Chord Shine
V4: Chord Shine2
V5: 7th Lead2
V6: Pulse Tone
V7: Noise Tone
V8: Mod Lead
There is some explanation in the performance wich shows you how to adjust the patch as it should. tnx to iPassenger who helped making this possible.
Enjoyy the fat unison! Best played with 61 keys
Poly Unison v1.prf2
Polyfonic Unison!
 Filename:  Poly Unison v1.prf2
 Filesize:  6.57 KB
 Downloaded:  2019 Time(s)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Dec 30, 2008 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I've made 2 audio demo's ,
one for the variations with no extra fx.
and a cubase audio demo with sample based drums & percussion. wich has overal dynamics and reverb fx.
This ofcourse does not work on the demo version, i have not tested it without expansion, so i might create a stripped off version, but some issues need to be fixed first.
Poly Unison Variation Demo.mp3
The Variations
 Filename:  Poly Unison Variation Demo.mp3
 Filesize:  2.18 MB
 Downloaded:  1281 Time(s)
Poly Unison Audio Demo.mp3
The Audio Demo
 Filename:  Poly Unison Audio Demo.mp3
 Filesize:  1.07 MB
 Downloaded:  1259 Time(s)
