bugbrand
Posted: Sun Jan 31, 2010 5:02 am Post subject:
Question about LM13700 offset |
Hi there,
I've been using the LM13700 for plenty of designs, but have a bit of a head-scratcher regarding offset voltages..
Here's an example little circuit:
A pretty standard setup!
- the exp. converter is a standard 'simple' approach used widely for simple applications
- the LM13700 part is straight from the datasheet - a simple LoPassFilter (I've been trying out for glide)
My question::
The Offset trimmer is, of course, necessary to null out any offset and ensure that there is no DC offset at the output.
BUT!
The DC offset changes with the control current?!
-- when the current is at its maximum (ie Manual control up to V+ -- less than 1mA current) the offset changes -- its only a few millivolts and I've not accurately measured it, but for pitch control it is noticeable as a slight offset in pitch.
If anyone can give an ideas to why I'm experiencing this I'd be very grateful!
Is it, perhaps, that the Exp Converter is too simple?
Big thanks! _________________ http://www.bugbrand.co.uk
gwaidan
Joined: Mar 07, 2009 Posts: 53 Location: Sydney, Australia
Posted: Sun Jan 31, 2010 11:40 pm Post subject:
| In the OTA the difference in apparent input voltage resulting from offsets (as well as from the TL072 in the feedback loop) gets amplified by the control current just like any signal input. If you have it trimmed to zero then it should (ideally) stay zero regardless of control current-you've kept input impedance identical between channels so no problems there... |
bugbrand
Posted: Mon Feb 01, 2010 7:48 am Post subject:
Well...
Looking a bit more closely.
I was initially using a TL072 -- this would give an offset range of around 300mV -- that's quite a lot!
The only other dual opamp I've got in SOIC8 at the moment is an LM358 -- changed over to this and the offset range falls to around 100mV. Hmm, maybe getting somewhere..
I think I'd better get some 'special' opamps with especially low offset voltages and try out like this.
Probably partly down to my overly standardized use of mainly TL07x for most applications! _________________ http://www.bugbrand.co.uk
frijitz
Audio files: 54
Posted: Mon Feb 01, 2010 7:52 am Post subject:
Re: Question about LM13700 offset |
| bugbrand wrote: | My question::
BUT!
-- when the current is at its maximum (ie Manual control up to V+ -- less than 1mA current) the offset changes -- its only a few millivolts and I've not accurately measured it, but for pitch control it is noticeable as a slight offset in pitch. |
Yep, that's the nature of the beast (and a well known and much disscussed effect). There is quite a bit of variation between devices, even between batches from the same manufacturer. I spent weeks going through a large batch of devices to select out those with low offset variation. This was a killer problem for some of my chaos circuits because the patterns change so rapidly with the system parameters.
The CA3280 is much better than the 13700 in this regard. That's the main reason I still use it for most of my own circuits.
Ian |
bugbrand
Posted: Mon Feb 01, 2010 8:00 am Post subject:
Thanks for chiming in Ian - I was hoping for input from you!
Ahhhh-shhhh...
So the trouble is likely from the LM13700 rather than the opamp (TL072)?
That's a bit of a spanner for me then! _________________ http://www.bugbrand.co.uk
Sound
Posted: Mon Feb 01, 2010 8:14 am Post subject:
Could it be related to the characteristic described in page 4, first graphic, on the LM13700 documentation?
Could it be solved restricting the span from 5 to 200 or 300mA?
Edited again the span according the graphic  Last edited by Sound on Mon Feb 01, 2010 11:26 am; edited 2 times in total |
frijitz
Audio files: 54
Posted: Mon Feb 01, 2010 8:27 am Post subject:
| bugbrand wrote: | | So the trouble is likely from the LM13700 rather than the opamp (TL072)? |
Probably some of both. For my testing circuit I actually had to separately null the opamp offset.
Ian |
bugbrand
Posted: Mon Feb 01, 2010 10:43 am Post subject:
| Sound wrote: | Could it be related to the characteristic described in page 4, first graphic, on the LM13700 documentation?
Could it be solved restricting the span from 50 to 200 or 300mA? |
Yes, interesting point - I'd already looked a bit at this but shall try out some more. I'd initially thought it was only going 'out-of-tune' at highest current so had tried to limit the max. current.. certainly needed to tweak it somewhat.
I may resort to Vactrols in the end! _________________ http://www.bugbrand.co.uk
Sound
Posted: Mon Feb 01, 2010 11:37 am Post subject:
| Just thinking on this, only an idea without check, is it wild think -if the two OTAs of one LM13700 are matched -and the ratio Iabc/offset is same in both- use one of them -same input Iabc, without input signal- just for cancel the offset of the other, just inverting it? |
bugbrand
gwaidan
Posted: Tue Feb 02, 2010 2:04 pm Post subject:
| Re the TL072-I've found the LF412 is much much better in this regard altho a bit more expensive-worth a try. |
