cable tree or stand?
Page 1 of 1 [12 Posts]
numbertalk
PostPosted: Mon Feb 02, 2009 11:34 am    Post subject: cable tree or stand? Reply with quote  Mark this post and the followings unread
Looking for something portable (i.e. not a wall-mount rack) to manage my patch cables. What do you guys use?
Apologies if I should not have posted this in the DIY section because I'm not really that interested in building my own (I have limited time for projects and would rather spend it building circuits Very Happy) but figured someone here would be able to recommend something.
Thanks.
Adam-V
PostPosted: Mon Feb 02, 2009 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I drape my cables over a cheap "X" type keyboard stand that is only expanded to its minimum extent. It's easy enough to pick up and move when I need to.
Adam-V
guitarfool
PostPosted: Mon Feb 02, 2009 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know of anywhere that you can BUY one, but it's not hard to MAKE one. The trick is to get a sturdy mic stand that's tall enough if you have 6-foot cables. Scott Juskiw's is the fanciest one, detailed instructions here:
http://www.tellun.com/motm/diy/cabletree/cabletree.html
Hope this helps.
EdisonRex
Audio files: 172
PostPosted: Mon Feb 02, 2009 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I always thought it would be really cool to take an old coat stand (pick your preferred era) and make a cable hanger out of it. Depending on the era you could use wire, wood, plaster, etc to make a comb to hold the cables.
I just use a slab of wood with slots cut in it, it is counterweighted by the oscilloscope... Sad I wish I had space for patch coat racks...
[/i]
Garret: It's so retro.
bugbrand
PostPosted: Tue Feb 03, 2009 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Hope this helps.
Oh wow - that IS cool
I've used the Mic-stand technique before, but not the 'triangle' approach.
I've DIY'd holders 'til now but just got a few of the Pomona holders -- though, in some ways I think they're too closely spaced (for bananas)
http://www.bugbrand.co.uk
BananaPlug
PostPosted: Tue Feb 03, 2009 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I made this years ago out of wood scraps and some screw-in hooks. It's still good enough.
 Filesize:  58.79 KB
 Viewed:  165 Time(s)
fluxmonkey
PostPosted: Tue Feb 03, 2009 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hope this helps.
inspired by seeing larry hendry's version at AHMW, my vision was to take a large contractors bucket, cut cable-width slots down the sides plus a mikestand-sized hole in the bottom... mount it on the stand, or flop the cables inside for transport/storage.
of course, i thought of that years ago and still haven't done it...
b
www.fluxmonkey.com
BOB-SNARE
PostPosted: Tue Feb 03, 2009 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I always thought a tie-rack would work.
Maybe an electric one.
http://www.proidee.co.uk/shop/SID_0123456789_02_GB/F=produkt_formular/P=02_GB_561423/K=02_GB_2461/HI=produktuebersicht_text
Adam-V
PostPosted: Tue Feb 03, 2009 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Only if it can be controlled by gate and CV signals!
Adam-V
numbertalk
PostPosted: Wed Feb 04, 2009 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for all the suggestions!
I'd seen Scott Juskiw's design and it's perfect. However, and this is going to make me sound really lame, the triangular pieces of wood is what made me hesitant to go with this one. I might still try this anyway because it does look great, but some of the other suggestions here sound like they'd work just fine for me as well, even if it's just till I feel I have the time to build something nicer myself.
Pehr
PostPosted: Wed Feb 04, 2009 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now that gave me an IKEA-idea Very Happy
http://www.ikea.com/se/sv/catalog/products/27866183
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Photon
PostPosted: Wed Feb 04, 2009 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I take the synth out, I have a couple Pamona cable 'combs' that I attach to the edge of the table where I'm playing with small c-clamps. Works fine and doesn't get any cheaper.
