Broadwave
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Mon Sep 28, 2009 5:56 am Post subject:
ARP VCF's - 3 in my Odyssey |
I recently managed to get a MKIII Odyssey on ebay... not working... VERY cheap
After spending a few hours, I got it fully functional and have since added both the 12db 4023 and the "Moog Infringement" 4035 to go along side the 4075, which has been fixed (swapping the 4 x 4k7's for 2k2's) for full frequency response.
I tried two attempts at the 40235 board with no luck, so I just copied the buffer sections for audio, CV and feedback and used the output to feed all 3 VCF's - works like a dream.
Now that I've finally had the chance to compare the "Moog infringement" VCF with ARP's later Norton design, I have to say that the difference is very subtle. They sound remarkably similar, although I think the 4035 has the edge, but only slightly - the resonance is smoother and drops off slightly at the lower frequency end, and FM control is punchier (maybe that's to do with the log converters?)
I've also installed a switch to invert and level shift the saw output of VCO 1 to the S/H mixer - The "White Face" Oddy's output is sawtooth, while the MkII & III is ramp, which makes a difference when you sample the LF output of VCO 1.
I now have the choice, by way of 3 simple switches, to choose which version of the Odyssey I want - All I have to do now is tidy up the wiring, fix the boards in and drill 3 small holes for the switches... I'm waiting until I have a steady hand
337.57 KB |
| Viewed: |
164 Time(s) |
268.24 KB |
| Viewed: |
167 Time(s) |
_________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Fri Oct 02, 2009 3:11 pm Post subject:
Andy,
That's just classic! I think you need to change your forum name to Mr. Arp! |
