For those using the MOTM960....
Page 1 of 1 [7 Posts]
Bodega
PostPosted: Mon Nov 16, 2009 7:22 am    Post subject: For those using the MOTM960....
Subject description: How are you hooking yours up?
Possibly dumb question here:
I'm wondering if the three rows of 156 connectors on the 960 are all interchangeable, in the sense that you can plug a +/-15v source into any of them, and plug the modules needing power into any other?
In other words, I assume there's no advantage in connecting the voltage source into the screw-down terminals on the ends?
Bonus question: can anyone tell me what the caps are for? The SynthTech site says it's for "bulk bypass capacitance" but I'm not sure what that means in this usage.
much thanks!
Matthew
sduck
PostPosted: Mon Nov 16, 2009 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not a dumb question, it comes up fairly often. And there are several answers. The one I like, and you'll probably like, is from Paul Schreiber directly - that yes, you can just plug a regular power connector from a 900 supply or whatever into one of the .156 connectors and power a few modules from the other connectors. I'll add that you probably don't want to power too many modules this way - if you're going to run more than 3 or 4, you probably want to use 16awg wire directly to the screw terminals.
The caps - I don't know. But I'm sure they do really good things, so don't worry about them.
Bodega
PostPosted: Mon Nov 16, 2009 9:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, but if they do really good things, all the more reason to find out! Laughing
Seriously, though: Thanks for the info.
Bodega
PostPosted: Mon Nov 23, 2009 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Still curious about those caps....
Should I assume that any given power supply that one would be connecting to it would have bypass caps of its own, and that those caps are just in keeping with the engineered-to-the-hilt nature of MOTM stuff?
numbertalk
PostPosted: Mon Nov 23, 2009 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you know why this is the case? I'm using a 960 and am powering many modules just this way and want to know if I really should change it.
sduck
PostPosted: Mon Nov 23, 2009 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not really sure, I'm just parroting things I've read. You might want to ask on the MOTM yahoo group, which is the best way to contact the experts on this - http://launch.groups.yahoo.com/group/motm/
Bodega
PostPosted: Mon Nov 23, 2009 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a good tip - I just posted there about it.
