silent way - an alternative to Motu Volta
Page 1 of 1 [6 Posts]
oisin
PostPosted: Thu Jul 02, 2009 1:50 am    Post subject: silent way - an alternative to Motu Volta Reply with quote  Mark this post and the followings unread
looks interesting - http://www.expert-sleepers.co.uk/
matrix12x
PostPosted: Sat Oct 03, 2009 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
has anyone tried this out yet?
I wanted to, but I need a different interface as mine blocks DC.
os
PostPosted: Sat Oct 03, 2009 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Plenty of opinions here:
http://www.muffwiggler.com/forum/viewforum.php?f=35
EdisonRex
Audio files: 172
PostPosted: Sat Oct 03, 2009 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
If your interface is AC coupled, nothing will work, but you know that, right?
If you're going to spend money on another interface, maybe consider a Kenton, unless you think you'll use a lot of outputs (ie multi channel CVs)...
I haven't tried Silent Way (nor have I tried Volta), I have played a little with the Max/MSP program that does the same, but I have a Kenton so I don't have as much need for it. I do have DC coupled audio interfaces. No reason for it not to work with the right hardware.
That said, MW or kvraudio.com seems to have plenty of opinions, indeed.
Garret: It's so retro.
Cardinen
PostPosted: Thu Dec 10, 2009 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Work well here !! up to 6 octaves perfectly tuned on my DIY modular !!
Audio card: motu 828mkII OSX
good work Expert Sleepers Laughing
Scot Solida
PostPosted: Fri Dec 11, 2009 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Works great here, too. I usually use the MIDI-to-CV modules in my Synthesizers.com system or a Roland MPU-101 for this sort of thing, but Silent Way does things that those can't, like forcing my cantankerous old VCS3 to snap into tune. For me, this is the main value of Silent Way and things like it. Sure beats spending hours fine-tuning the input scaling on that old synth.
