 Forum index » Artists » Seraph
Using a ribbon controller as note generator
Page 1 of 1 [20 Posts]
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Jun 26, 2009 3:11 pm    Post subject: Using a ribbon controller as note generator
Subject description: featuring Doepfer R2M
today I have received this ribbon controller I ordered a few days ago.
this is the first sample I recorded. is'a bit crude but I am just posting it to let you know I am enjoying it.
arrow Listen to ribbonflute
GaryRea
PostPosted: Fri Jun 26, 2009 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was amazing, Carlo! Very Happy I have to admit, when I saw the photo, I thought I was going to hear some cheesey Theremin-like sounds, so this really blew me away. That's a fairly decent flute sample. Did you use the Ribbonflute to make the percussion track, also, or was that done with another instrument?
Gary
http://cdbaby.com/cd/garyrea
http://www.artistserver.com/gary_rea
http://mixcraftlive.com/members/385/
http://amiestreet.com/music/gary-rea/reinvention/
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 27, 2009 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Gary
thanks Gary Exclamation
see this one for more explanations.
The percussion tracks are only a couple of audio samples in loop mode Wink
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 27, 2009 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
arrow read this one and following replies Exclamation
GaryRea
PostPosted: Sat Jun 27, 2009 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I remember seeing something, years ago, about using ribbons controllers; don't recall where or when, though. So, the technology's really nothing new. I suppose one can order it from anywhere, right? 250 Euros works out to about $351 US. Not too bad, I guess. I've paid more for software synths. This would work perfectly with my current setup, via USB. There's no end to the sounds I could use with it, via VST, either. Cool! Very Happy
Gary
Inventor
Audio files: 267
PostPosted: Sat Jun 27, 2009 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice audio sample, very expressive controller. Cool
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 27, 2009 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
right Exclamation
Moog manufactured module 955/956 in the seventies
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 27, 2009 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
...then there was the kurzweil Expression Mate
and probably many more...
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 27, 2009 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks, Les Exclamation Very Happy
Audio files: 304
PostPosted: Sat Jun 27, 2009 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Ha! nice once Carlo!
Did you program the scale into the ribbon controller? You used some other controller as well, or is the expression coming from the dynamics of playing only?
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 27, 2009 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
only once Question Shocked
Audio files: 304
PostPosted: Sat Jun 27, 2009 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
oops ... "one"
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 27, 2009 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
the surface of the ribbon controller is quantized to "major scale" but the scale is loaded with the flute sample (Spectrasonics Omnisphere).
the dynamics is all coming from playing: pressure, in this case, is assigned to control (open/close) the filter.
the ribbon does not send midi velocity.
Audio files: 304
PostPosted: Sat Jun 27, 2009 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah ... it does pressure, great! Wondered if you had maybe used a breath controller for that, but no need then.
GaryRea
PostPosted: Sat Jun 27, 2009 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
So, the scale is a function of whatever sample or VSTi you're using, then.
Gary
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 27, 2009 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
excerpts from (downloadable) manual
Doepfer wrote:
Several quantization tables are available and can be chosen in this menu:
12 tone all 12 semitones of an octave are generated
Major only the tones of the major scale are generated
Minor only the tones of the minor scale are generated
Quart only fundamental and quart
Quint only fundamental and quint
MajorCh only the tones of the major chord are generated
MinorCh only the tones of the minor chord are generated
Quart6 only fundamental, quart and sixth
Quint6 only fundamental, quint and sixth
MajCh6 only the tones of the major chord and the sixth are generated
MinCh6 only the tones of the minor chord and the sixth are generated
Quart7 only fundamental, quart and seventh
Quint7 only fundamental, quint and seventh
MajCh7 only the tones of the major chord and the seventh are generated
MinCh7 only the tones of the minor chord and the seventh are generated
quart=fourth
quint=fifth
Doepfer wrote:
...a parameter determines the number of octaves (1 - 5) that correspond to the full
range (~ 50cm) of the position sensor.
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Jul 09, 2009 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
arrow R2M and CC#1
How to create timbral variety with CC#1 using a R2M as note generator.
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Jul 13, 2009 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
arrow Soprano RibbonSax
arrow Listen to Soprano RibbonSax
another experiment using the Doepfer R2M ribbon controller.
xjscott
PostPosted: Tue Jul 14, 2009 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that kicks ass.
Maybe the first synthesized sax I've heard that didn't suck, this sounds pretty convincing.
Clearly this ribbon controller allows a much finer, and perhaps more intuitive, level of inflection control than is possible with pitch levers.
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Jul 14, 2009 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Jeff
well, the ribbon controller has 2 sensors (position and pressure) plus, you can choose the range of midi notes it generates and other parameters are programmable: pitch quantization, pitch bend amount, transposition etc.
The soprano sax sound is still a sample but the slight pitch variations that are introduced, thanks to the ribbon controller, makes it more convincing.
