 Forum index » Clavia Nord Modular » G2 Patches - Completed » Acoustic
Phase Invertion Synthesis - Violin
Page 1 of 1 [3 Posts]
Tabarn@kdeca.lis
G2 patch files: 4
PostPosted: Mon Jul 05, 2010 9:18 am    Post subject: Phase Invertion Synthesis - Violin Reply with quote  Mark this post and the followings unread
I had a good idea of how to create a nice sound, and it worked pretty well! I am kind of new to sound synthesis, but for everything I have red or heard about it, no one ever talked about that trick.
I created a patch where I got two filters HP with resonance. Both filters are set exactly the same, then I take the output of one and I invert the phase then I mix both signals together, so there is no sound coming out. Then if you apply minor changes to one or both filters, the signal comes back again with cool harmonics!
Using the patch mutator I created that violin style sound without much work... I locked many critical modules so you can just go and randomize it to get a wide variety of sounds!
Laurent Allen-Guérard
Délicate Frénésie
DelicateFrenesie_PhaseInverted_DelayFMModulation_Violon.pch2
There is much more to do than that preset! I found the trick last week.
 Filename:  DelicateFrenesie_PhaseInverted_DelayFMModulation_Violon.pch2
 Filesize:  2.29 KB
 Downloaded:  2516 Time(s)
Audio files: 303
PostPosted: Mon Jul 05, 2010 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice :-)
Some diverse timbres seem possible ... on laptop speakers now though ... will try on bigger speakers later.
Tabarn@kdeca.lis
G2 patch files: 4
PostPosted: Tue Jul 06, 2010 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone ever heard of that technique to synthesize sound?
