Voltage Controlled Quadrature Function Generator
PostPosted: Tue Sep 05, 2017 1:06 pm    Post subject: Voltage Controlled Quadrature Function Generator
Subject description: again!
After almost 10 years i thought it was time to tackle this again.
So with kind permission from Thomas i will offer PCBs and Panel for his classic triangle QFG soon!
There will be a main PCB, an eurorack adapter PCB, and an eurorack panel. The actual main PCB is not very friendly to be adopted to other formats, just because it is rather dense and there was no room for a lot of mounting holes and MTA headers for easy and convenient manual wiring. Nonetheless i will provde a documentation showing you the wiring for the front panel components.
this is how the PCBs and a built module will look like:
i will post about it here and in the fonik subforum as soon as these are available.
