 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
NM1 great editor....but
squarewhite
PostPosted: Sun Aug 08, 2010 2:36 am    Post subject: NM1 great editor....but Reply with quote  Mark this post and the followings unread
hi,
i'm using a nord modular Key version 3.03, a midisport 2x2 and intel core 2 duo OSX 10.5.8, java 1.5
in my java extension folder, I've got libMandoM3D installed, (it's the package direct from www.mandolane.co.uk/)
i've tried both version of NM1, OSx and Standalone.
error messag for OSx version;
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1281259241497 [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1281259241497 [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmProtocol.heartbeatImpl(NmProtocol.java:5Cool
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular$SchedulingProtocol.heartbeatImpl(NordModular.java:252)
at net.sf.nmedit.jnmprotocol2.AbstractNmProtocol.heartbeat(AbstractNmProtocol.java:154)
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:114)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:358)
... 10 more
for java version;
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1281259689544 [error=-1001]
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1281259689544 [error=-1001]
... 10 more
trying just osxmidispi on OSx version,
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1281259793291 [error=-1001]
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: Communication timed out: 1281259793291 [error=-1001]
... 10 more
i guess it's all the same error messages.
I've also tried putting the synth in ext mode but error messages still appear.
can someone help on this? if someone has got this working on the same os and mac and interface and keyboard as mine, maybe you could share your java extension folder. this would be a great help for many of us which haven't got this working yet!
It's a great software thanks for the effort. but nevertheless the problems are putting this out to the great wide world of nord modular user. i don't mind donating for the efforts that you guys put in, so to continue this wonderful machine instead of just keep buying newer stuff!
btw, everything worked fine in the NM Editor software, just that it's buggy. Well we all know that.
any help would be appreciated!
thanks!
