 Forum index » Discussion » Composition » Project Zylaphon
Bugs and Issues
Post new topic   Reply to topic Moderators: bachus
Page 1 of 1 [2 Posts]
bachus
PostPosted: Wed Dec 29, 2010 6:51 pm    Post subject:  Bugs and Issues Reply with quote  Mark this post and the followings unread
This thread will be used to post bugs and issues. The first reply will contain those I've found or verified and will be continuously updated. Anyone coming across a bug/issue is requested to post it in this thread.
Thanks,
rc
bachus
PostPosted: Wed Dec 29, 2010 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you enter a second key in the mode box during creation of a prj, closing the prj creation box gives you the msg that you need to select a mode
Copy and insert measure fails only the first measure (only)
generic copy doesn't copy stem data for notes
when meter map window is opened it and meter-manger need to be set to top most
No code to draw 64th & < rests
Left tie toggle on wrong keypad page
(in ChBarDiaonic) public override void UpdateStaffLimitsUpdateSetaffLimits needs to update the element locus
"Repair The Channel Bar" Doesn't
DspIdxKeeper() has problems -- create and delete two views and it asserts
SetPivotPivotStopBeamData et al mixes GPPA format and beam pivot processes -- refactor
need to reset ch barstaff limits when element type is changed etc
ChannelAndMeasureTool if you delete all the measures but one you can't add new measures
FIXED
moving a note tied to a tuple causes the non-tuplet to move double the intended amount
