Fonik dual triple resonator
Page 1 of 1 [10 Posts]
Audio files: 160
PostPosted: Tue Jun 02, 2015 9:28 am    Post subject: Fonik dual triple resonator
Subject description: diy module
Hullo Smile
I have finished a test panel design for my 2 triple resonator pcb's that Matthias posted over to me .
In order to get the 2 resonators squeezed onto a single skrog panel ( 100mm x 250mm) I have decided to leave off the individual audio in's & out's and just keep the single in & out sockets for each resonator pcb , a switch on the left near the bottom will switch the audio routing from 2 resonators in series ( input to in1 / output at out2) / 2 separate resonators / 2 resonators in parallel (1 audio to both in's & outputs at both out sockets) .
I have populated both pcb's and now ready to wire the connections , I think I will print off the simple black & white layout and glue to a test panel before ordering the final blue sticker .
more pics as the build goes on Smile .
 Filesize:  563.37 KB
 Viewed:  743 Time(s)
Audio files: 160
PostPosted: Mon Aug 10, 2015 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Smile
Finally got the wires attached to the 2 pcbs , one thing im not sure about is the J8 terminals on the pcb, the boards are going on a big format panel (250mm X 100mm) , should I leave the J8 as is in the pic ? .
I have a couple of other panels in the design stages , once I get the stickers for all panels im working on , this should come together quite quick Smile
 Filesize:  853.34 KB
 Viewed:  777 Time(s)
PostPosted: Mon Aug 31, 2015 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the late reply. i must have missed the notifications for the latest posts here!
anyays, J8_ is a header for e micromatch connector, which carries the three single outputs and the LFO. it was meant to internaly connect the resonator module to a forthcoming x-pan/fader. so just leave it off (or install a micromatchright away, hehe)
Audio files: 160
PostPosted: Sun Nov 22, 2015 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Matthias .
Now got the front good sticker on the panel and the hardware fitted to the 250mm X 100mm X 3mm panel , more sockets due in the post soon to finish the panel , then it's wiring up time Very Happy .
 Filesize:  501.73 KB
 Viewed:  656 Time(s)
Paradigm X
PostPosted: Mon Nov 23, 2015 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
you seem to like wiring dave...
Smile im just trying to design a panel for my version. i got the circuit working (sounds great mattias, thanks!) but no panel.
PostPosted: Tue Nov 24, 2015 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think i still have one of the first eurorack prototype panels somewhere. could this be helpfull?
Paradigm X
PostPosted: Wed Nov 25, 2015 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
For me? No thanks, I do MOTM format stuff. thanks anyway!
Audio files: 160
PostPosted: Wed Dec 02, 2015 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finished , and it's working perfectly, fantastic Smile
To save a couple of patch leads I installed a on/off/on toggle switch for different modes .
Parallel = filter 1 & 2 both fed from audio input 1 ( a veroboard non-inverting buffer was used to copy 1's input to 2 input) .
Dual = 2 separate filters.
Series = audio into filter 1 input , audio output from filter 2 output.
The un marked switch on the lower mid right is an after thought , switched to the left = all cv inputs receive LFO 1 , switched to the right is separate lfo's.
Why are there 5mm leds on the top 2 and the rest are 3mm leds ???
Someone accidentally used a 6mm bit on the top row before double checking the cross hairs (oooops Wink )
a pic of the front end......
 Filesize:  338.53 KB
 Viewed:  676 Time(s)
Audio files: 160
PostPosted: Wed Dec 02, 2015 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds to follow at the weekend Smile
Audio files: 160
PostPosted: Sun Dec 06, 2015 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some sounds of it in action .....
1 mp3 :- Sequenced vco saw with no resonator , Fades into saw with 1 triple resonator.
2 mp3 :- Seq saw to 2 resonators in Parallel mode , changing both Lfo speeds.
3 mp3 :- Still in Parallel mode but LFO 1 sweeping all 6 cv inputs.
4 mp3 :- Series mode resonator 1 fed into 2 , adjusting controls.
5 mp3 :- Series mode , a Korg X5 general midi standard strings sound fed into the resonators.
Thanks Matthias , I really like this module , I can see me using it for modular & normal keyboards too , fantastic .
Hex Resonator plain , then resonated.mp3
 Filename:  Hex Resonator plain , then resonated.mp3
 Filesize:  1.33 MB
 Downloaded:  1155 Time(s)
Hex Resonator Parallel mode = 2 outs to vca.mp3
 Filename:  Hex Resonator Parallel mode = 2 outs to vca.mp3
 Filesize:  1.12 MB
 Downloaded:  1094 Time(s)
Hex Resonator Parallel mode - LFO 1 to all cv inputs.mp3
 Filename:  Hex Resonator Parallel mode - LFO 1 to all cv inputs.mp3
 Filesize:  1.19 MB
 Downloaded:  1063 Time(s)
Hex Resonator Series mode - adjusting Lfo's & cv amounts.mp3
 Filename:  Hex Resonator Series mode - adjusting Lfo's & cv amounts.mp3
 Filesize:  1.77 MB
 Downloaded:  1107 Time(s)
Hex Resonator Series mode - Korg X5 general midi string sound through resonators.mp3
 Filename:  Hex Resonator Series mode - Korg X5 general midi string sound through resonators.mp3
 Filesize:  2.15 MB
 Downloaded:  1082 Time(s)
