Posted: Fri Jan 27, 2012 4:42 am Post subject:
PCBs for the fonitronik Sequential Switch (4th run) Subject description: taking advance orders until 13 FEB 2012 |
EDIT Feb 6th:
i will take advance orders until Feb 13th
ETA of the PCBs would be early march. i won't take any money until i hold the PCBs in my hands. i will contact you concerning payment details when time has come. paypal preferred.
again some of you indicated interest in this project, so i would do a 4th run if there would be interest in more than at least 30 PCBs.
BTW i think this module will be a good companion for the symplSEQ.
simply post in this thread, contact me via email or even PM, and tell me how many PCBs you will take. BTW i won't take any money until i hold the boards in my hands...
i personally think it is a very useful module. it provides one output/input that can be routed sequentially to four inputs/outputs. the step and reset of the switch can be controlled manually and/or by a clock. the number of steps is selectable (2, 3 or 4 steps), which is very nice if you want to switch live between different sources/destinations. all signals between -15V and +15V can be switched, due to the DG412 (or MAX313) IC used.
here you will find the latest documentation:
Building Docs
PRICING:
each PCB 10.-USD/7.-EUR
+ packaging & postage
deutschland: 1 PCB 1.-EUR, 2+ PCBs 1.50 EUR
europe: 2 PCBs 2.-EUR, 3+ PCBs 4.-EUR
outside europe: 2 PCBs 4.-USD, 3+ PCBs 6.-USD
this is how it could look like:
SeqSwitch fonitronik.de
Tech Buddy at Random*Source Last edited by fonik on Sun May 06, 2012 2:26 pm; edited 2 times in total |
Mongo1
Posted: Fri Jan 27, 2012 8:11 am Post subject:
I'll take 3 - they look pretty useful...
Thanks
Gary |
inlifeindeath
Joined: Apr 02, 2010 Posts: 316 Location: Albuquerque, NM
aladan
Posted: Wed Feb 01, 2012 8:43 pm Post subject:
2 please
Any suggestions where I might pick up a few DG412 or MAX313 cheaper than Futurelec (MAX313 @ $5.90 each?) |
ejr27233
Posted: Thu Feb 02, 2012 1:44 am Post subject:
| I'll take 2 please |
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Mon Feb 06, 2012 7:37 pm Post subject:
Matthias: I haven't actually added it up, but it's looking like between here and Muff's you may hit your minimum!
Count me in for 2.
Thanks for considering another run; I was disappointed that the last one came during a self-imposed moratorium on adding to my backlog!
Mark |
Posted: Tue Feb 07, 2012 12:17 am Post subject:
indeed. it wil happen. i will have to list al pre-orders up, and then i will set a cutoff date. from then on the delivery date is fixed... _________________
Tech Buddy at Random*Source |
citric acid
keithwin
Posted: Thu Feb 16, 2012 5:14 pm Post subject:
| Blimey, only just seen this again, I would like three if not too late? |
Posted: Thu Feb 16, 2012 11:46 pm Post subject:
have some spares, so no problem at this point. _________________
keithwin
Posted: Fri Feb 17, 2012 4:26 am Post subject:
| That's a definite from me, thankyou |
textual
Joined: Dec 05, 2009 Posts: 78 Location: New York City
Posted: Mon Feb 20, 2012 10:58 pm Post subject:
yes. _________________
janvanvolt
Joined: Nov 24, 2005 Posts: 285 Location: Mainz, Germany
mark_olson
Posted: Sat Mar 03, 2012 11:50 am Post subject:
| fonik wrote: | | indeed. it wil happen. i will have to list al pre-orders up, and then i will set a cutoff date. from then on the delivery date is fixed... |
Did I miss this? Or is it still forthcoming?
Mark |
Posted: Sun Mar 04, 2012 1:01 pm Post subject:
it happens right now. the PCBs should arrive soon, and i ordered some spares as always. so still time to jump on the bus. _________________
mark_olson
Posted: Sun Mar 04, 2012 2:12 pm Post subject:
| fonik wrote: | | ...still time to jump on the bus. |
I'll take two!
(If this isn't enough of a commitment, or if you want prepayment, let me know.)
Mark |
Posted: Wed Mar 14, 2012 12:17 am Post subject:
now all PM's/emails are sent.
if you have the feeling you missed something or i missed to contact you, just let me know... there are spares avilable. _________________
keithwin
Posted: Tue Mar 20, 2012 1:53 am Post subject:
| Boards waiting for me at work this morning, very smart, many thanks Matthias. |
Posted: Tue Mar 20, 2012 2:09 am Post subject:
you have a soldering iron at work?  _________________
keithwin
Posted: Tue Mar 20, 2012 6:28 am Post subject:
Wish I had, would solve all sorts of problems :0)
The soldering I do at work needs significantly higher temperature, platinum for example  |
