Key-Synced(?) Arpeggiator using Modules
gosmith
G2 patch files: 4
PostPosted: Sun Jan 31, 2021 2:51 pm    Post subject: Key-Synced(?) Arpeggiator using Modules
Subject description: implementing a module-based arpeggiator
The modules in the 2 columns on the right are for testing - other ways to use the Voice No., and testers for the signal comparisons.
It's basically working, but I'm frustrated that I can't get the voice sequencer (SeqLev2) to step in straight time - even without Reset signals, it responds to the timing of your playing, which I don't want.
Also you can't change the # of voices on the fly, so it has to be set in advance, the SeqLev2 has to match that # of steps, and you have to always play that many keys!
Suggestions welcomed!
SyncedArpeggiatr.pch2
 Filename:  SyncedArpeggiatr.pch2
 Filesize:  2.47 KB
 Downloaded:  894 Time(s)
