Tim Kleinert
G2 patch files: 236
Posted: Wed Mar 25, 2009 6:08 pm Post subject:
ElasticAudio X Subject description: deluxe polyphonic elastic audio sampler with force-pitch and formant control |
dear friends,
Here's the final version of the polyphonic elastic audio synth. It offers vastly improved sound quality and precision, plus added functionality like forcing audio material to a specific pitch and controlling formants.
This design differs from the polyphonic granular synth in a fundamental way: The granular approach chops up the source audio arbitrarily into grains which clock at a specific frequency. Since these grains overlap, there is always some phase cancellation in the resulting audio which has to be alleviated by jittering the playback speed of the individual grains. Also, the grain clock bleeds into the audio considerably, and also has to be masked by jitter.
This approach works totally differently. It intelligently scans the source audio for single full wavecycles, clusters those into larger chunks of selectable size and realigns them over the time axis -all in realtime. Hence, all the artefacts (or interesting effects, depending on your taste ) of the granular approach don't occur and the pitch information of the source audio is preserved far more faithfully.
I also added something completely new: "forcing to pitch". When this function is engaged, the audio is indeed "forced" onto a pitch of choice. Technically speaking, the waveform clusters are hardsynced to a carrier wave, and the sharp flanks are smoothed away. When this is activated, the cluster pitch control actually changes into a formant control -so pitch, time and formants are all controllable in realtime.
There's a demo mp3 attached, which demonstrates my voice saying "one two three..." (sorry ), playing some notes on the keyboard and stepping through the 8 variations.
Input Section:
INPUT Source, Pad -select external input channel and pad
INPUT Monitor -listen to the input (running through the input limiter, drive and EQ)
SAMPLE Capture -samples audio (2.7 seconds)
INPUT Limiter -input dynamics
INPUT Drive -overdrive for the input, can be useful
INPUT EQ -EQ for the input, can be useful to add eg. "air" to voices
Elastic Audio Section:
SAMPLE Positio -position pointer in the sampl; also assigned to modwheel (for scrubbing the sample)
SAMPLE Speed -playback speed: from -64 (backwards) to 0 (freeze) to 64 (forwards), independent of pitch; assigned to the pitch stick (for cruising through the sample)
SPEED KBT -lets playback speed track the keyboard
SAMPLE Pitch -playback pitch of the sample, independent of speed;When pitch-forcing is activated, this parameter turns into a formant control.
PITCH KBT -sample pitch keyboard tracking
CLUSTER Size -sets the size of the wave cluster
CL-SIZE Source -this is a nifty one: when set to "cycles", the "CLUSTER Size" parameter determines the amount of single wavecycles to be clustered (when set to 0, this equals 1 wavecycle, which lets you scan through the individual waveforms of your source audio with the pitch stick. It's fun, try it.) When set to "time" however, the "CLUSTER Size" parameters determines the absolute temporal size (=time) of the cluster. This results in an uniform cluster size regardless of playback pitch.
PITCH forcing -activates the pitch forcing function
WAVE smoothing -amount of smoothing applied to the pitch-forced waveforms
FORCED PITCH Coarse, Fine -destination pitch
POSITION Jitter -jitters the sample position
PITCH Jitter -jitters the sample playback pitch
CL-SIZE Jitter -jitters the cluster size ("time" mode will logically render this ineffective)
F-PITCH Jitter -jitters the destination pitch of the pitch-forcing process
The rest is vanilla stuff -filter, amp envelope, chorus, stereo delay, reverb, blablabla.
As usual, this patch uses a DSP per voice, so 3 voices for unexpanded and 7 for expanded G2s.
Also, this patch uses 3 interslot buses!
yupp, that's it. Enjoy.
best,
tim
The demo mp3 demonstrating the 8 variations:
1 - straightforward sample playback, freeze with the pitch stick
2 - freeze with some jitter, cruising about with the pitch stick
3 - force-pitch tonal pad
4 - glitchy warble (big clusters with copious pitch jitter)
5 - slowly scanning single wavecycles
6 - fixed force-pitch with keyboard-tracking formant control
7 - warbling cloud
8 - force-pitch pad with extreme formants
| audio demo of the ElasticAudioX patch; sampled voice saying "one two three...", noodling around and stepping through the 8 variations. |
 Download (listen) |
| Filename: |
OneTwoThree.mp3 |
2.31 MB |
| Downloaded: |
2740 Time(s) |
| Final version of the polyphonic elastic audio synthesizer. Vastly improved algorithm, better sound quality, more functionality. |
 Download (listen) |
| Filename: |
ElasticAudioX_TK.pch2 |
8.47 KB |
| Downloaded: |
2661 Time(s) |
seraph
Editor
Audio files: 33
Posted: Thu Mar 26, 2009 12:56 am Post subject:
unexplainable but awesome
 _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
iPassenger
Joined: Jan 27, 2007 Posts: 1070 Location: Sheffield, UK
G2 patch files: 78
drapdap
Posted: Thu Mar 26, 2009 3:28 am Post subject:
the demo is so funny, i listened three times by now...
Tim, we're so glad you are.
biggest possible thank you!
robert |
mtvic
Joined: Feb 03, 2003 Posts: 526 Location: Townbank Cape May NJ
Posted: Thu Mar 26, 2009 4:35 am Post subject:
Sounds like Konky the Robot from Pee Wees' Playhouse.
Very useful fun pch _________________ "I'm the transmitter' I give information."
>>> Kraftwerk Radioactivity<<< |
Posted: Thu Mar 26, 2009 7:49 am Post subject:
No wonder Clavia have discontinued the G2! This is f**king tapped (probably quite literally too eh?) Tim!!
You are a genius mate
Oh yes Clavia- they have probably realised from your patches alone why it was so silly to leave out sampling on the G2, and why sampling will now appear on the G3........Hooray!! Well just a thought!
And thanks for uploading that mp3 too!  _________________ ACHTUNG!
W.T.
Joined: Jul 11, 2004 Posts: 272 Location: The Netherlands
G2 patch files: 11
Posted: Sun Mar 29, 2009 3:32 am Post subject:
this is going t be a great Sunday afternoon !
mother misty
Joined: May 13, 2004 Posts: 681 Location: Ghent / Belgium
G2 patch files: 130
Posted: Sun Mar 29, 2009 3:49 am Post subject:
| W.T. wrote: | this is going t be a great Sunday afternoon !
+1
Fantastic patch tim! thank you so much for sharing
misty. _________________ http://www.myspace.com/mariodemeyer |
BobTheDog
Posted: Sun Mar 29, 2009 4:10 am Post subject:
I just think its amazing you can do this on a G2!
Bloody Clever stuff. |
gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Sun Mar 29, 2009 8:02 am Post subject:
Another 'Magic' patch from you Tim!
To boldly go where no man has gone before
Thanks for sharing! |
Chrono
Audio files: 37
G2 patch files: 38
Posted: Sat Apr 11, 2009 6:34 am Post subject:
Nice this one is pretty easy to control!! Very Nice Patching!
tnx i will try to use this for some nice vocals  |
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Fri Apr 17, 2009 2:15 am Post subject:
WTF! OMG! Amazing!
The mp3 demo is simply stunning. _________________ Cheers,
Albert |
