 Forum index » DIY Hardware and Software » emSynth
Help with this circuit:: Oscillator 4093
Page 1 of 1 [3 Posts]
javi.electronic
PostPosted: Wed May 13, 2020 1:45 pm    Post subject: Help with this circuit:: Oscillator 4093
Subject description: Trying to work this circuit
Hello there!
Here is my first post. I am trying to work this schematic. I am using the 4093 chip. I tried to built 2 oscillators but it's not possible the operation. It doesn't start, not works. Please, anyone can to help me with it.
http://fluxmonkey.com/electronoize/4093_Oscillator.htm
all the best
Javier
Sven
PostPosted: Thu May 14, 2020 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello and welcome Javier,
Have you measured supply voltage at pin 14 of the 4093 and connection to ground/ minus on pin 7? Which 4093 do you use? Can you post a picture of your build? This makes troubleshooting easier for us.
Sven
javi.electronic
PostPosted: Thu May 14, 2020 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your reply. I fixed it. Just I would like to add a small effect to it. Could you to help me with it? It could be a different generator for example that does a kind of delay effect.
