 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Cubasis 1.8 update coming
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [3 Posts]
GovernorSilver
PostPosted: Thu Apr 03, 2014 9:52 am    Post subject: Cubasis 1.8 update coming
Subject description: Automation and MIDI CC!
http://www.steinberg.net/forums/viewtopic.php?f=183&t=57782
cheers compress jackson dancing party! party time! banana
Some old stuff on VIRB
Audio files: 235
PostPosted: Wed Apr 23, 2014 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can see why you are in emoticon bliss! Very Happy
GovernorSilver
PostPosted: Wed May 21, 2014 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
The update has been officially released:
Some early reports of the update not working with polyphonic aftertouch, but I'll have to see...
The initial post of that thread has been updated. Copied and pasted for your convenience:
NEW FEATURES
- Automation
- MIDI CC's, program changes, aftertouch support
- Mixer side global control panel
- Phase inversion plug-in (for audio channels)
- Redesigned effect rack
- Audiobus 2.0 support
IMPROVEMENTS
- The sustain pedal is now recorded as MIDI events (All sustain pedal problems solved!).
- The mod wheel is now recorded as MIDI events.
- Color-coded inspector nodes for automation, inserts and sends were added.
- The pitch bend range behaviour has been adapted to match Cubase. MicroSonic pitch bend range is configurable per track in the Inspector.
- Pitch bend wheel movement is visible when playing back pitch bend events.
- Audiobus 2.0 support.
FIXES
CB-1519 Scrolling the list of available Inter-App Audio effects now works as expected.
CB-1557 Freezing a muted or soloed track no longer leads to wrong mute/solo button behaviour.
CB-1218 Recording of pitch bend events now works as expected.
CB-1506 Polyphony setting no longer affects metronome playback.
CB-1508 A problem that occurred when inserting Inter-App Audio effects that feature MIDI input has been solved.
CB-1511 Event names that contain special characters will now be displayed correctly.
CB-1507 Playback of events that contain notes of length zero no longer result in hanging notes.
CB-1514 Fixes a problem where monitoring of audio tracks did not work as expected.
CB-1515 Inter-App Audio effects are no longer disconnected when they go silent.
CB-1529 Input clipping indicators now work as expected.
CB-1530 Track freeze of audio events has been corrected when being used with overlapping parts.
CB-1604 Fixes an issue where after undo or redo too many tracks were record-enabled.
CB-783 Gain related effect parameters no longer crackle when they are modified during playback.
CB-1705 Performing a mixdown of a 96 kHz project during playback no longer leaves reverb tail at mixdown start.
