 Forum index » DIY Hardware and Software » The Repair Shop
roland sh5 lfo2 failing
Page 1 of 1 [4 Posts]
9 volts
PostPosted: Thu Jan 23, 2014 4:02 pm    Post subject: roland sh5 lfo2 failing Reply with quote  Mark this post and the followings unread
Hi there, I wonder if anyone can can help me. My sh5 lfo2 seems to be beginning to fail. Basically the rate slider seems to work but with random results. This morning when I turned it on the rate started fast then slowed down, maybe also a little irregular in its rhythm. I had a lot at the circuit and it looks like there is a electrolytic capacitor in there. So maybe I will replace this one. Just wondering if anyone has experienced this?Thanks
PostPosted: Mon Jan 27, 2014 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, the slider may be your smoking gun. More likely to fail than the capacitor.
Bill
9 volts
PostPosted: Thu Jan 30, 2014 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I quickly sprayed in some contact cleaner into the pot and it has almost fixed it. So this is definately the problem. Thanks again
PostPosted: Thu Jan 30, 2014 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
OK good. Your most welcome. Smile
