Hedefar
Posted: Sun Feb 17, 2013 12:19 pm Post subject:
TH VCO-1 parts list in the making Subject description: I'm making a list and checking it twice! |
Hey guys,
I'm planning on building the Thomas Henry VCO-1.
But because I am still a DIY newbie, I felt that I was missing a summary of all the parts that would be used, in order to help me better understand the proportions and expenses of the project. Therefore, I have made a spreadsheet containing all the needed parts.
The spreadsheet can be found here and was based on the schematics that can be found here.
But because I am inexperienced, I would like it if someone could look through the list while looking at the schematics, and comment on what kind of capacitors I should choose in the different places. Apart from the caps, I think everything else is in place but I am open to (and hoping for) suggestions for improvement.
Please let me know what you think of this list.
If you think that it is useful, I will send it to Scott Stites so he can add it to the website, if he wants to. |
Posted: Sun Feb 17, 2013 8:01 pm Post subject:
| I checked list to schematic, marking off the list and it looks good from that direction. I didn't go back and do it the other way, marking off on the schematic... |
Hedefar
Posted: Mon Feb 18, 2013 3:52 am Post subject:
| elmegil wrote: | | I checked list to schematic, marking off the list and it looks good from that direction. I didn't go back and do it the other way, marking off on the schematic... |
Great, thanks for helping me out again, elmegil
Any comments on what kinds of capacitors should be used?
Only C3 was specified and should be of polystyrene type.
I am guessing that the rest should be obvious... but I am a newbie, so to me, it isn't. There are so many kinds to choose from!
And, by the way, is "polystyrene" the same as "styrene"? Polystyrene is nowhere to be found and I can only find the latter at Mouser. |
Hedefar
Posted: Mon Feb 18, 2013 4:55 am Post subject:
| Hedefar wrote: | | elmegil wrote: | | I checked list to schematic, marking off the list and it looks good from that direction. I didn't go back and do it the other way, marking off on the schematic... |
I got the question answered at here, if anyone is interested
http://www.mutable-instruments.net/forum/discussion/comment/47468#Comment_47468 |
Posted: Mon Feb 18, 2013 5:58 am Post subject:
In general I haven't yet found any practical difference between using polystyrene, mylar film, or C0G/NP0 ceramics. Part of the point is that you need to use a high quality cap that is temperature stable.
Of course, keep in mind I've been doing this just about a year now, so you should pay more attention to things more experienced folks have to say . |
james.watkins@gmail.com
Tim Servo
Joined: Jul 16, 2006 Posts: 924 Location: Silicon Valley
Posted: Sat Sep 07, 2013 1:10 pm Post subject:
TH VCO-1 parts list in the making |
Actually, no, the answers there were not correct. The tolerance of the cap isn't really the issue here. The value can be slightly off in a VCO, and it is very easy to compensate by just tweaking the Coarse or Fine tune pots. What you really want in a timing cap is something that is temperature stable. As mentioned before, mylar film, styrene, or ceramic C0G caps are good candidates. If you get a styrene / polystyrene cap, just be careful with your soldering as they can be damaged with too much heat.
One more note: when I build a VCF, then I want the tuning caps to match as closely as possible. In that case, I usually just buy ten or even twenty film or polystyrene caps and measure them to get the four closest together.
Tim (timing is everything, especially if you're a capacitor) Servo |
siri
Posted: Mon Apr 21, 2014 9:43 pm Post subject:
The list i made, if any errors i can edit (i checked twice)
| Code: | VCO-1 PARTS
RESISTORS
R1= 47R
R3= 390R
R4= 820R
R5,R6= 1K
R7= 1K8
R9-R11= 2K2 (qty=3)
R12= 3K
R13= 5K1
R14-R17= 10K (qty=4)
R18,R19= 12K
R20,R21= 18K
R22= 20K
R23= 22K
R24= 27K
R26-R31= 100K (qty=6)
R40= 150K
R41= 330K
R42= 1M
R43= 1M5
R44,R45= 2M2
R46= 3M3
TRIMMERS
R2= 100R
R25= 50K
R32,R33= 100K
POTENTIOMETERS
R34-R39= 100K LIN(qty=6)
CAPACITORS
C1= 47pf any kind
C2,C3= 0.001uf polystyrene cap (or low-tolerance cap)
C4>C11= 0.01uf (qty=8) ceramic or tantalum
C12= 0.22uf any kind
C13,C14= 10uf electrolytic
ICS
IC1= CA3080
IC2-IC4= TL072 (qty=3)
OTHERS
R8= 2K TEMPCO 3300ppm (or 3500)
D1= 1N914
Q1-Q4= 2N3904 (qty=4)
Q5-Q6= 2N3906
IC SOCKETS
acidblue
Joined: Jun 26, 2009 Posts: 226 Location: The Darkside
Posted: Tue May 13, 2014 4:48 pm Post subject:
The links to the spread sheet are dead.
Any chance of getting new links?? |
