 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
iOS 8.3
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [3 Posts]
crucifyme
PostPosted: Sun May 10, 2015 11:43 am    Post subject: iOS 8.3
Subject description: sound issue on iPad Air
Hello. Recently, the use iPad Air to iOS 8.3. Discovered sound distortion (clogging, rattling, crackling) device through the speakers on some synths sounds. For example, in z3ta-bass1-deep70s ebass or phase84-leads-hyperflute (if you take two or three notes at the same time). On the piano in the garage band. This is evident in the volume close to the maximum. When listening to music, the effect is not observed. I read that on iOS 8.3 do have a problem with sound. Interesuet- is the norm or speakers are covered?
Audio files: 232
PostPosted: Sun May 10, 2015 3:59 pm    Post subject: Re: iOS 8.3
welcome Crucifyme to electro-music.com
Let us pray crucified Let us pray
I have an iPad 4 and discovered similar problems. When you drive speakers with the headphone output, you have to cut down the volume to about 75%. Even if you use a USB audio interface, the same problem can show up. This happens with all versions of IOS, unfortunately.
crucifyme
PostPosted: Mon May 11, 2015 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for responding
