will0000
Posted: Mon Apr 20, 2015 6:19 am Post subject:
Simple VCA troubleshoot |
| I've built the Simple VCA, and have it mostly working in my 12v system. I have trimmed it according to the instructions, and everything is OK except that the whole thing is very quiet, almost inaudible. If I adjust A2 (init. level) to bring up the volume the CV input no longer does anything. I've checked the component values several times and I can't find anything wrong. Hoping for some help. |
yusynth
Posted: Thu Apr 23, 2015 12:02 am Post subject:
Check your wiring as well.
Post hires photos of your PCB (component and track faces) so we can check your build. _________________ Yves |
will0000
Posted: Fri Apr 24, 2015 1:11 pm Post subject:
So what is happening is when I set A2 (initial level) so that I get envelope response from CV1 input, the volume is way too low. If i turn A2 to raise the overall level, I no longer get any envelope response, just constant volume level. I hope this is clear. I don't have an oscilloscope so I can't trim according to the instructions but I understand the idea, I think. |
will0000
Posted: Fri Apr 24, 2015 1:13 pm Post subject:
will0000
Posted: Tue Apr 28, 2015 5:03 am Post subject:
| I should add also: the transistor pair is a matched pair of BC548C. I have been experimenting with the values of R10 and R11, it seems the smaller I make them, the closer it gets to working normally (right now they are 4.7K). Besides that everything is true to the original Yusynth schematic. |
