 Forum index » DIY Hardware and Software » The Repair Shop
Korg Poly 800 coil replacement??
Page 1 of 1 [7 Posts]
agustindead
PostPosted: Tue Jul 19, 2016 9:37 am    Post subject:  Korg Poly 800 coil replacement?? Reply with quote  Mark this post and the followings unread
Hello everyone, I need some help with a dead poly 800... I'm not sure this was the problem, but the -5v rail wasn't giving me the expected voltage, I saw a coil in bad shape but definitely ruined it when taking it out.
The thing is... what is this? How / where do I look for a replacement? What does it do in the circuit? Is there any way to work around it? I asked around a bit but had no luck... They usually only had single coils, with two terminals and had no idea what this was. I don't know how to specifically ask for it anyway...
I'm attaching a picture plus the schematic.
 Filesize:  175.06 KB
 Viewed:  9982 Time(s)
 Filesize:  490.56 KB
 Viewed:  541 Time(s)
agustindead
PostPosted: Tue Jul 19, 2016 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Full schematic page:
 Filesize:  3.84 MB
 Viewed:  536 Time(s)
Audio files: 297
PostPosted: Tue Jul 19, 2016 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes coil .. actually two coils wound on the same core, which makes it a transformer.
In this case it is used in a switching power supply to generate a more or less stabilized -5V supply. The exact value of that voltage probably is not too critical, but will have a look at the schematic and when my assumption was wrong I will write a bit more on it.
You probably only melted the plastic a bit which is not essential for the functioning, and could try to solder the wires into the PCB again and then stabilize the while thing with some sort of glue.
Replacement would need some experimentation, as the transformar is a bit od a critical component in this configuration.
Alternatively you get all of the -5V generator out and buy a DC/DC converter to do the job for you.
Audio files: 297
PostPosted: Tue Jul 19, 2016 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, what I see in the schematic is that the -5V is used on some analog switches and on the big divider chip to allow for signals around zero .. so it is not too critical indeed, like -4.5 or -5.5 would work too. Don't know how badly it deviated tho ...
agustindead
PostPosted: Tue Jul 19, 2016 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply! I'm trying now to attach some pins to the wires back again and as you said all seems fine... one thing I don't understand though is that center tap leading to R9 and +9v... On the little coil there are just three wires, do I connect that third wire there, leaving the other end disconnected? The winding got pretty messed up, hope it's not too crucial....
I have no experience with those... any part I should look for? Seems like the easy way out.
agustindead
PostPosted: Wed Jul 20, 2016 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I was able finally to make the synth start. I did a really ugly job winding and gluing that thing in place, but I was able to get -5.5v and then it worked beautifully. It also took me some time to realize I should tie two wires to use that as the center tap... now I understand the sizes of the primary and secondary in the schematic...
Again, thanks for the help! Sweet having that thing back and running. Very Happy
Audio files: 297
PostPosted: Thu Jul 21, 2016 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant!
Was just about to ask some questions, but you found and answered 'm already :-)
