Capacitive Controller
Page 1 of 1 [6 Posts]
deltamodulator
PostPosted: Fri Jun 17, 2016 2:16 am    Post subject: Capacitive Controller
Subject description: a project with sonic
sonic and I had a great chat + telephone call last night about creating a capacitive sensing controller, probably spherical in shape. Here are some of the highlights of our discussion as well as my fading memory can recall.
approximately spherical in shape
sonic wants flats, so maybe dodecahedron
can experiment with a cube initially (that would be a first for me, approximating a sphere with a cube, lol)
sonic has no 3D printer, I have a very good 3D printer (Ultimaker 2+)
I just now received some electrically conductive filament
can print tesselations or all-in-one or half-spheres (half-shapes)
use Arduino-programmed ESP8266 chip for comm out of sphere, or just use
simple Arduino for starters and transition to WiFi later.
WiFi chip embedded in an electrically conductive device is not exactly smart lol
can use a Feather from Adafruit to get battery management with USB charging.
can also use inductive charging from Adafruit (then no connector at all, just s sealed shape!)
use a Processing program on the Mac/PC/Linux to receive WiFi and send out OSC locally or across the web.
Would be cool to make sensor readings available on the web. Maybe use Adafruit's cloud.
So, we had plenty of ideas and not much resolute thinking. In particular it's going to be challenging to extend the electric field of the sensors to outside the sphere. Anyway, we've got a project on our hands. I want to get something printed and playable by next week's Summer Solstice event.
Les out, praise the Lord!
sonic
PostPosted: Fri Jun 17, 2016 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one Les. Yeah I think a new kind of tactile controller would be really cool, and I like the kind of playful direction this is going. I'm still a little hazy on what kind of responsiveness we can get from a capactive-based thing. I think it's important that the musician can get a predictable response from the same controller every time, so that different playing techniques could be developed over time without unexpected freaky output.
Is it worth considering other kinds of sensors too? I'd really like the controller to have a kind of elastic response when you press it in places - aftertouch basically. What kind of pressure sensors do midi keyboards use for aftertouch? Would it be possible to print a kind of pressure sensor using your new techniques?
Many questions. Anyhoo back to making veggie burgers...
deltamodulator
PostPosted: Sat Jun 18, 2016 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
After some discussion and imagineering plus some Thingiverse browsing, I have decided to make a dodecahedron (12 sides, not 20). In this shape every side is 5-sided and there are 12 sides. The 12 sides can be decorated in a variety of ways:
o 12 tribes of Judea (Israel)
o 12 months of the year
o 12 signs of the zodiac
o 12 step program steps
o certainly others I missed
So that's a good thing about 12 sides. See attachment for the two attempts at a dodecahedron I have tried. The first one I got the angles on the edges wrong. The second one has the correct angle but some printing error due to nozzle diameter and the way slicers work caused a slight gap. I will attempt to trim that gap on future attempts.
Need to make the next one big enough to hold the electronics and the batteries, plus add battery holders, electronics mounts, and a means of keeping the top and bottom attached.
Les
Les make a dodecahedron!
Two Dodecahedrons (12 sides each), left 1st try, right 2nd try
 Filesize:  1.66 MB
 Viewed:  533 Time(s)
deltamodulator
PostPosted: Sat Jun 18, 2016 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, and I re-connected the circuit with the ESP8266 module and the 9DOF module on a breadboard, plus loaded the software that I had put together before. Now next what is needed is to add WiFi communications.
Les
Les program a WiFi chip!
deltamodulator
PostPosted: Sat Jun 18, 2016 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is an image of some progress... Rechargeable AA NiCd batteries I bought some time ago, and 3D printed battery holders attached to 3D printed board mounting plates.
Les
Les doin' CAD again...
The controller bottom half with power and electronics mounts, still need to stabilize rather than "float" them.
 Filesize:  48.1 KB
 Viewed:  531 Time(s)
deltamodulator
PostPosted: Sun Jun 19, 2016 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the yellow (fourth try) controller with sufficient internal electronics to make a WiFi based orientation sensing device. Will add software and electronics with batteries soon.
 Filesize:  1.84 MB
 Viewed:  557 Time(s)
