 Forum index » Clavia Nord Modular » G2 Patches - Completed » Classic
MKS50 Hoover
Page 1 of 1 [3 Posts]
grantransom
G2 patch files: 13
PostPosted: Sat Jun 18, 2005 5:38 pm    Post subject: MKS50 Hoover Reply with quote  Mark this post and the followings unread
This patch is a 'Port' from the NM using the G2 demo,
The osc structure is based on the actual MKS's, which I have here for reference - and after some discussion with Rob Hordijk who suggested some architectures.
The chorus too was developed from the actual unit ( I measured the waveform in pure anorak fashion)
The thing with the ported version is, the Pulsewave only seems to have 50-100% duty cycles, as opposed to the NM. Which I think has made the patch sound a bit less 'wild' (subtly) - which is not such a good thing for this sound...
However it is pretty close to the MKS, I'm a G2 noob so the module use may be a little less efficient than a veteran, and I'm getting clicks on the chorus, but I think that may be due to the demo.
Grant.
MKS50 HooverGR.pch2
Port from the NM of the MKS hoover
 Filename:  MKS50 HooverGR.pch2
 Filesize:  2.45 KB
 Downloaded:  1942 Time(s)
MKS50 HooverGR.pch2
Port of the Roland MKS50 hoover from the NM
 Filesize:  2.45 KB
 Downloaded:  2001 Time(s)
Grant
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Jun 18, 2005 9:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds excellent
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Jun 18, 2005 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's nice. The patch is much cleaner than my old one, sounds smoother too, more like the original. Cheers
