Patch Mutator Modules
Page 1 of 1 [4 Posts]
forcefielder
PostPosted: Sun Feb 19, 2017 9:30 pm    Post subject: Patch Mutator Modules
Subject description: For discussion of the 'LiveMorph' and 'Auto' modules, or any others that alter the patch mutator
So I am trying to use these modules but they aren't working. I am running Wren in Wine so its quite possible (probable) that they don't work because of that. But after reading the documentation I didn't see anything specific so I thought I'd ask. Each module , 'LiveMorph' and 'Auto', have inputs and when a signal (like an lfo for example) peaks it triggers the input and then that will virtually press the morph/randomize/etc button right?
(I think he mutator ability is already brilliant - it was my favourite part of nord modular - and I also think adding the controls just takes it to a new level, it makes it possible for the synth a self evolving organism...kuudos!!!!!)
forcefielder
PostPosted: Sun Feb 19, 2017 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
got live morph to work!
Audio files: 297
PostPosted: Mon Feb 20, 2017 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great :-)
The live morph does a sort of a fade trough the variations.
The auto module uses a trigger to perform one of three randomization functions.
So you use Wine .. under Linux?
I tried it myself on a Mac and that was like .. yuck ... so apparently not that bad for you then?
forcefielder
PostPosted: Mon Feb 20, 2017 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah its not great in wine, but i just installed it to give your program a try. If i figure out a way to get windows on here I'll try it out.
