 Forum index » DIY Hardware and Software » The Repair Shop
Dumb question, how do you tighten up 3.5" jacks?
Page 1 of 1 [2 Posts]
cslammy
New postPosted: Mon Nov 05, 2018 9:34 am    Post subject: Dumb question, how do you tighten up 3.5" jacks? Reply with quote  Mark this post and the followings unread
I have a bunch of 3.5" mono jacks in my modular synth. These all have a threaded ring that holds them to the panel. EG, Switchcraft 35RAPC2AV or a clone of it...
Question: these come loose sometime, does anyone have a suggestion about the best tool to tighten them up?
Right now I use needle nose pliers, which don't get them that tight, and can scratch the front panel.
I notice all the rings have small notches 180 degrees apart, perhaps there is a dedicated tool I can use to hook into those notches to get it good and tight? Anyone know what this is?
New postPosted: Mon Nov 05, 2018 11:23 am    Post subject: Re: Dumb question, how do you tighten up 3.5" jacks? Reply with quote  Mark this post and the followings unread
yes, there is a tool for that. I got this one from mouser earlier this year,
works a lot better than needle nose pliers.
