CoreAudio Error
Lueasy
PostPosted: Fri Feb 01, 2019 7:35 am    Post subject:  CoreAudio Error
Subject description: CoreAudio Error
Recently upon opening MiniAudicle and running the VM I am met with this message:
Code:
[chuck]: system error: (CoreAudio unknown error) getting sample rate info...
2019-02-01 09:23:31.733 miniAudicle[7678:327644] Failed to connect (table_menu) outlet from (miniAudicleVMMonitor) to (NSMenu): missing setter or instance variable
2019-02-01 09:23:31.733 miniAudicle[7678:327644] Failed to connect (audio_changes_warning) outlet from (miniAudiclePreferencesController) to (NSTextField): missing setter or instance variable
I am running ChucK version 1.4.0.0 on macOS Mojave 10.14.2. My output runs just fine, it seems my input is not connecting properly.. Any advice on this would be much appreciated!
