Help with power supply
Page 1 of 1 [3 Posts]
Taller de Teknologia Libr
PostPosted: Sun Jul 07, 2019 6:37 pm    Post subject: Help with power supply
Subject description: 40106 burned after coneccting to ac/dc adaptor
Hi , i`m building some 40106 oscilators and i soldered an ac/dc conector directly to the board and ended up burning it. Could you give me some advice , i want to remove the 9v battery powe supply and power it up from the adaptor , do i have to build a power supply or something like that , would apreciate some help.ç
Thanks and excuse my english not my primary language.
RF
Audio files: 28
PostPosted: Mon Jul 08, 2019 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
A 7809 voltage regulator and a few capacitors is all it takes - search MFOS wall wart power supply.
www.sdiy.org/rfeng
PostPosted: Tue Jul 09, 2019 11:59 am    Post subject: Re: Help with power supply
the board, the connector or the chip ?
If you burned the chip than make sure you use a DC adapter, the polarity is correct and the voltage isn't too high (< 18V).
A voltage regulator might not be needed depending on the adapter you use.
