VCO frequency pot size
Page 1 of 1 [5 Posts]
soffiuson
PostPosted: Tue Oct 29, 2019 8:20 am    Post subject: VCO frequency pot size
Subject description: Does the size matter?
Hi.
I have built two VCO's that are both working fine. I broke one of the frequency pots on the second oscillator while forcefully tightening it to the front panel Embarassed Unfortunately I don't have another 22k pot to replace it. I have a bag full of 100k pots so I was thinking... Are these pots not basically voltage dividers? What would be the effect of replacing them with 100k pots? I have already replaced them and the oscillator works although I have not calibrated the cv tracking. Is there a reason not to do this?
Regards
Kolbeinn
JovianPyx
Audio files: 224
PostPosted: Tue Oct 29, 2019 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome I see you're new here - Welcome! welcome
Without a schematic it's hard to say. Not all variable resistors are used as voltage dividers. And some that are used that way are also used as a load resistor for a transistor amplifier. Still others are used as variable resistors. So while in some circuits the value matters greatly (load resistor) and others it doesn't matter much. In some circuits, a higher value may result in increased noise.
We can help much more if you post a schematic of your VCO.
Time flies like a banana.
corruptio optimi pessima
soffiuson
PostPosted: Tue Oct 29, 2019 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
Thank you! Very Happy It is the yusynth VCO:
http://www.yusynth.net/Modular/EN/VCO/index.html
The pots I'm referring to are the coarse and fine tune potentiometers.
Regards,
Kolbeinn
 Filesize:  120.61 KB
 Viewed:  278 Time(s)
JovianPyx
Audio files: 224
PostPosted: Tue Oct 29, 2019 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
The website calls the pots P1 through P6, but they aren't shown on the schematic.
EDIT: I see the wiring diagram now and yes, it's a voltage divider.
I'd test-replace it with the 100K pot and see if the VCO performs as it should. If it works, I'd leave it.
Worst case: might be a bit of noise going into the frequency control circuit.
Best case: it could just work as spec'd.
gabbagabi
PostPosted: Tue Oct 29, 2019 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
i would say for the fine tune pot it does not matter much,
cos it is connected to a 3,3M resistor
the 100k will behave bit different from the 22k,
but at least there is no risk in using 100k instead
