Mirror mirror ...
PostPosted: Tue Sep 01, 2020 5:33 pm    Post subject: Mirror mirror ... Reply with quote  Mark this post and the followings unread
Toyed a bit with HTML5 video and canvas tags - it wants to use your camera - but everything it does with it is on your computer only.
There is a mirror, a gray-scaled rotating derivative, a low pass filtered one with some rotation mixed in and a motion-detector of sorts.
All the javascript and stuff is contained in the HTML document, you can use "view frame source" to see it.
Anyways, it was relatively easy to get this going, so maybe someone can use the code for something. Not sure in what browsers it will work, I've used firefox only.
Edit: just tested with chrome, worked here too.
