 Forum index » Discussion » Diversity in electro-music
diagram of amplifier
Post new topic   Reply to topic Moderators: bbinkovitz
ROSELJR
PostPosted: Sat Aug 28, 2021 12:08 am    Post subject: diagram of amplifier Reply with quote  Mark this post and the followings unread
I want to ask if you have a simple circuit schematic diagram of LM258 as the amplifier? Will it burn out if the positive and negative poles of the power supply are reversed?
Thanks in advance.
Reference:https://www.utmel.com/components/lm258-op-amp-ic-uses-pinout-and-datasheet?id=448
