OneOfTheseDays
Posted: Mon Dec 29, 2008 11:47 am Post subject:
Good jacks and pots? |
| What kind of 1/4" mono pots should I order for my synth? I need them inexpensive and they can't take up alot of space on my front panel. Also, what pots do you guys use? Add links if you can. |
sduck
Posted: Mon Dec 29, 2008 2:16 pm Post subject:
Switchcraft 112a's - from mouser.com, part number 502-112A
Scott Deyo at Bridechamber has a similar thing a bit cheaper - https://bridechamber.sslpowered.com/bridechamber.com/Jacks.html
Pots? I love spectrol 249's, but can't afford them anymore. Alpha pots are fine though. Get a mouser and/or a digikey catalog - pdf or paper, and search through them. Once you place an order, the paper catalogs are going to start arriving anyway... |
bugfight
Joined: Aug 02, 2007 Posts: 188 Location: Arlington, TX USA
Posted: Mon Dec 29, 2008 2:30 pm Post subject:
+1 switchcraft, it's not worth going cheap on these...
hmmmm "one of these days i'm going to dance with the gypsies"?
or "one of these days, pow"?
or ? |
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Mon Dec 29, 2008 3:57 pm Post subject:
It's a very bad mistake to go completely by price for jacks. I've seen some real garbage.
I have been pleased with Neutrik NYS229. Well under $1 each even in small quantities, and they are very well built. (.69 in quantity of 100 last time I bought them)
If you need the plugs, they are NYS224 - also quite nice for very reasonable price - especially in quantity.
I have literally hundreds of these in use in my system with zero issues.
Alpha pots have been good to me, too.
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
fadeddata
Joined: Dec 27, 2004 Posts: 43 Location: Nashville TN
sduck
Posted: Tue Dec 30, 2008 3:50 pm Post subject:
| Fadedata may sound slightly trollish, but he has a good point - if you're early in the business of building synth modules, you might want to seriously consider using banana jacks. Especially if space is at a premium. No need for multiple panels with them, and they're very compact and reliable. If you're like me, and have over 400 1/4in jacks already installed, it's a daunting task to even consider switching, but if you're just starting out, think about it! |
fadeddata
Posted: Tue Dec 30, 2008 7:50 pm Post subject:
Didn't mean to troll...I even offered a link to the jacks everyone uses
They really are the best. It's amazing not using mults, it changes the way you think about patching up...
-dustin |
BananaPlug
Posted: Tue Dec 30, 2008 8:10 pm Post subject:
| Quote: | | Johnson Banana Jacks |
Yes. I have some gear with decades old Johnson jacks which are looser than than new Johnson jacks but none make any scratchy sounds or have needed to be cleaned. Kind of amazing but how could any connector with all that contact area, all of which gets a good wipe every time it's used, not be more reliable than minis or even 1/4" jacks? Oh, and they are very colorful too. |
Tasmanian Alkaloid
Joined: Jun 29, 2008 Posts: 116 Location: Isle De Mort
Posted: Wed Dec 31, 2008 4:30 pm Post subject:
| sduck wrote: | | Fadedata may sound slightly trollish, but he has a good point - if you're early in the business of building synth modules, you might want to seriously consider using banana jacks. Especially if space is at a premium. No need for multiple panels with them, and they're very compact and reliable. If you're like me, and have over 400 1/4in jacks already installed, it's a daunting task to even consider switching, but if you're just starting out, think about it! |
Yep, i'm about to house some stuffed pcb's, and i've settled for bananas. So the link that he provided has really helped me out. thanks fadeddata! |
fadeddata
Posted: Thu Jan 01, 2009 9:36 am Post subject:
Hey Tasmanian,
Make sure to check out the other colors!
-dustin |
Tasmanian Alkaloid
Posted: Thu Jan 01, 2009 4:51 pm Post subject:
I did, thanks! Now i need to work out a colour scheme for cv's & audio, and just how many i need. I'm also considering the system Buchla uses, of 3.5mm switching jacks for audio, and bananas for cv. It's a pretty smart way to keep track of a lot of panels
(apologies for hi-jacking a 1/4" thread ) |
stolenfat
Joined: Apr 17, 2008 Posts: 476 Location: Sunny Oakland California
Posted: Fri Jan 02, 2009 6:11 pm Post subject:
| do those johnston banana jacks have a ground connection? |
BananaPlug
Posted: Sat Jan 03, 2009 9:45 am Post subject:
| Quote: | | do those johnston banana jacks have a ground connection? |
No. There's just one wire in a banana plug patchcord. It relies on all your equipment having a common ground reference.
Banana plug 101 |
OneOfTheseDays
Posted: Sun Jan 04, 2009 12:59 pm Post subject:
| bugfight wrote: | +1 switchcraft, it's not worth going cheap on these...
or ? |
It's "One of these days I'm going to cut you into little pieces."
Props to whoever understands it. |
buchlajoe
Posted: Sun Jan 04, 2009 5:37 pm Post subject:
| pink floyd .... |
