today> Various Artists NYE concert
 Forum index » DIY Hardware and Software » Supercollider
Converting control rate to audio rate
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [8 Posts]
fadeddata
PostPosted: Fri Feb 06, 2009 11:42 pm    Post subject: Converting control rate to audio rate Reply with quote  Mark this post and the followings unread
I've been using Supercollider and a MOTU Ultralite with my modular and have had some very exciting results (http://fadeddata.com/?action=view&url=supercollider-and-motu). I feel as if I'm just barely scratching the surface.
Basically the MOTU Ultralite has DC Coupled outputs which allows you to use the device as a generic 4 volt signal generator.
I'm very interested in using Supercolliders Streams and Patterns utilities to create sequences and the like. I've played around EnvGen.ar and have had some success with creating sequences but I would much rather convert Streams and Patterns to audio rate information. K2A seems like the right thing...
Any thoughts or ideas?
Thanks,
-dustin
dewdrop_world
PostPosted: Sat Feb 07, 2009 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Streams and patterns don't run at audio rate but it should be pretty straightforward to run a control signal through to the audio outs. I think you'd need a SynthDef to receive the values from Control inputs, convert to ar (K2A.ar) and output them to hardware out buses.
Something like:
Code:
// 8 because the MOTU has 8 audio outs
SynthDef(\ctlX8, { |out, gate=1, ctl0, ctl1, ctl2, ctl3, ctl4, ctl5, ctl6, ctl7|
   FreeSelf.kr(gate <= 0);
   Out.ar(out, K2A.ar([ctl0, ctl1, ctl2, ctl3, ctl4, ctl5, ctl6, ctl7]));
}).memStore;
The gate is there because that's what the next thing needs to terminate the Synth when the pattern is over. The next thing is Pmono, which is like Pbind except that it runs one Synth, changing its parameters with each event instead of creating a new note.
Code:
p = Pmono(\ctlX8,
   \ctl0, Pwhite(0.0, 1.0, inf),...
   \delta, 0.25
).play;
Note that you'll have to scale the values in the pattern to the range -1.0 .. 1.0.
We could have some more fun and write a function whose input is the number of controls you want the Synth to process. Don't worry if this doesn't make much sense right away -- it's a bit advanced. Basically, it's duplicating in code the process that's used to make the Controls automatically out of the SynthDef function arguments. (See the Env and Control help files for more information about this technique.)
Code:
// or, build the controls dynamically
f = { |numCtls = 8|
   SynthDef("ctlX" ++ numCtls, {
      var   ctlNames = Array(numCtls+2).add(\out).add(\gate),
         out, gate, controls;
      numCtls.do { |i|
         ctlNames.add(("ctl" ++ i).asSymbol);
      #out, gate ... controls = Control.names(ctlNames).kr((0 ! (numCtls+2)).put(1, 1));
      Out.ar(out, K2A.ar(controls));
   }).memStore;
Hope that helps--
James
fadeddata
PostPosted: Sun Feb 08, 2009 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey James,
Thanks for the info! Here is a sequencer I built that is working somwhat well...
Code:
var freq_arr, slider_arr, dur, wave_arr, w_slider_arr, dur_arr, d_slider_arr, sequ;
dur_arr=Array.with(1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1);
freq_arr=Array.newClear(16);
wave_arr=Array.with([0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0]);
w_slider_arr = Array.newClear(16);
d_slider_arr = Array.newClear(16);
slider_arr=Array.newClear(16);
w=Window.new("Sequencer", Rect(20,20, 1000,420)).front;
w.view.decorator = FlowLayout(w.view.bounds);
v=CompositeView(w, Rect(5,5,290,390));
v.background = Color.rand;
v.decorator = FlowLayout(v.bounds);
t=CompositeView(w, Rect(205,5,290,390));
t.background = Color.rand;
t.decorator = FlowLayout(t.bounds);
s=CompositeView(w, Rect(405,5,290,390));
s.background = Color.rand;
s.decorator = FlowLayout(s.bounds);
16.do({
   arg i;
   slider_arr.put(i, Slider(v, 280@20));
   slider_arr[i].action = { freq_arr.put(i, slider_arr[i].value); };
16.do({
   arg i;
   d_slider_arr.put(i, Slider(t, 280@20));
   d_slider_arr[i].value = 1;
   d_slider_arr[i].action = { dur_arr.put(i, d_slider_arr[i].value); };
16.do({
   arg i;
   w_slider_arr.put(i, Slider2D(s,58@58).background_(Color.rand).x_(0).y_(0));
   w_slider_arr[i].action = { wave_arr.put(i, [(w_slider_arr[i].x), (w_slider_arr[i].y)]); };
x=Synth.new("DCout");
x.play;
sequ = Routine {
   var i=0, step=0, old_color;
   loop {
      i = i + 1;
      step = i%16;
      x.set("arg_0", freq_arr[step]);
      x.set("arg_1", wave_arr[step][0]);
      x.set("arg_2", wave_arr[step][1]);
      (dur_arr[step]/4).wait;
}.play;
b = Button(v, 180@20)
            .states_([
               ["Off", Color.black, Color.red],
               ["On", Color.white, Color.black]
            .action_({ arg butt;
               if(butt.value == 0,{sequ.stop},{sequ.resume});
I use the following SynthDef with it:
Code:
s = Server.local;
SynthDef("DCout",
{ arg arg_0, arg_1, arg_2, arg_3, arg_4, arg_5, arg_6, arg_7;
   Out.ar(0, K2A.ar([arg_0, arg_1, arg_2, arg_3, arg_4, arg_5, arg_6, arg_7]));
}).send(s)
The only thing not working is the On Off button....
-dustin
dewdrop_world
PostPosted: Tue Feb 10, 2009 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
What's not working with the on/off button?
James
fadeddata
PostPosted: Tue Feb 10, 2009 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey James,
Easy question, hopefully. Smile
When I instantiate a Routine how often does it's lambda/block get called? Is it based on the default TempoClock? Or the SystemClock? I'm wanting to put a bunch of stuff in sync.
Also what do you recommend I do for putting out a pulse (something similar to what Blip puts out) on the beat of the clock?
Thanks,
-dustin
fadeddata
PostPosted: Tue Feb 10, 2009 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey James,
No worries about the clock I think I've got it figured now...
Code:
SynthDef("clock",
      Out.ar(0, Impulse.ar(0));
   }).send(s);
Pbind(\instrument,   \clock, \dur, 2.0).play;
TempoClock.default.tempo = 240/60;
dewdrop_world
PostPosted: Thu Feb 12, 2009 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm... I expect that would pile up synths on the server because nothing releases them.
For this, I would probably use a trigger control and Pmono. Then it will use just 1 synth, and Pmono always cleans up after itself.
Code:
SynthDef(\clock, { |t_trig, out|
   Out.ar(out, K2A.ar(t_trig))
}).memStore;
// \trig is not a typo: it still maps onto t_trig in the Synth
c = Pmono(\clock, \trig, 1, \delta, 2.0).play;
Also, when using patterns, don't use send(s) - use memStore instead. It's to make sure the synth arguments work properly.
James
fadeddata
PostPosted: Fri Feb 13, 2009 10:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
James,
Thanks so much for the info. Are there more of these "special" variables? How do I find them? I see "dur" everywhere does it relate to something server side?
Thanks,
-dustin
