Fozzie
G2 patch files: 49
Posted: Wed Nov 24, 2004 12:50 pm Post subject:
slave to midi clock problem - help!! |
I guess I am missing something important again, but here's my problem:
on my G2 engine (v1.24), I can use an incoming midi clock (for instance from my micromodular) to sync to. The master clock becomes red in the editor, and it displays the current tempo. So far so good. Syncing delay tempo to this is also wonderful. But here's my problem: the clock generator modules refuse to sync and stop putting out a clock signal. Set to 'internal', everything runs smoothly. But set to 'master', everything is silent, no clocksignals are present.
Is this normal (I can't imagine)? I have searched the forum and the helpfunction for answers, but can't find them. Any help is appreciated!
Edit: of course, when I change the synth settings to 'ignore incoming midi clock', my problem is gone. But when syncing to an external clock, with the clockgenerator modules set to 'master', the problem occurs. |
G2 patch files: 626
Posted: Wed Nov 24, 2004 4:23 pm Post subject:
Re: slave to midi clock problem - help!! |
| Fozzie wrote: | Set to 'internal', everything runs smoothly. But set to 'master', everything is silent, no clocksignals are present.
This is strange, pressing the Master clock RUN button in the editor has no effect? |
Joined: Apr 03, 2004 Posts: 24515 Location: The Netherlands, Enschede
Posted: Wed Nov 24, 2004 6:48 pm Post subject:
At first it wouldn't work here as well, but after some fiddling with ignore external clock and start/stop it suddenly worked, that is the clkgen runs and syncs to the exrternal clock, but now it won't stop :-)
I looked it up in the manual and the help file but could not find anything about it, but I think it is designed to be started and stopped by external MIDI commands. Which makes sense when you link to an external sequencer.
When this is a problem you can use two LFO's that you sync to the master, to get both the 1/96 and 1/16 outputs, letting the slower one reset the faster one.
I never really used MIDI syncing, so i don't know if the NM Classic is able to send start and stop commands over MIDI, but a while ago I experimented a bit with this and I can't remember having had this problem then ... so .. puzzled a bit.
Jan. |
Fozzie
G2 patch files: 49
Posted: Thu Nov 25, 2004 12:00 am Post subject:
| g2ian wrote: | | Fozzie wrote: | Set to 'internal', everything runs smoothly. But set to 'master', everything is silent, no clocksignals are present.
Nope, I've tried everything I can think of, including the RUN button. Maybe it is indeed the start and stop signals that are needed, but it would be nice if one could override this with the RUN button or anything else. |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Thu Nov 25, 2004 6:25 am Post subject:
| I send my G2 a clock from an XL-7. I've noticed that sometimes I have to hit "play" on the XL-7 to start the clock. I don't think there is a way to do it from the micro. |
Fozzie
G2 patch files: 49
Posted: Thu Nov 25, 2004 6:39 am Post subject:
| OK, that'll be it then. Guess I have to do it with LFO's or sync my other gear to my G2. |
deknow
Posted: Fri Nov 26, 2004 10:51 am Post subject:
...just in case... |
....i had a similar thing and it turned out to be (duh), a midi loop with the clock data. since i was using the g2 as a master clock (and syncing everything else to it), i just set it to "ignore external clock" and everything worked fine.
deknow |
3phase
G2 patch files: 141
Posted: Sun Nov 28, 2004 2:25 pm Post subject:
The micromodular is not a proper syncmaster because it is not generating start commands.. and without such a comand the G2 dont starts.. You of cause have to enable external clock in the system settings.. but with a micromodular as clockmaster it cant work anyway.
Sven |
