 Forum index » DIY Hardware and Software » Rob Hordijk DIY Designs
Benjolin problem
Post new topic   Reply to topic Moderators: Rob
Page 1 of 1 [3 Posts]
jooks
PostPosted: Sat May 31, 2014 1:43 pm    Post subject: Benjolin problem
Subject description: 79L09 overheats
I got a pcb with Tekniks layout for the Benjolin and Im trying to make a modular module out of it. It kinda works but only for a minute and then the 79L09 gets to warm and shuts down. I have compared the schematics and layout and it looks ok but I dont quite understand the schematics fully. The layout has a dead end for the gnd coming from the 100n cap after 79L09. Is something missing here?
Any help is much appreciated!
All the best
Erik
rhbjln_5u_103.pdf
 Filename:  rhbjln_5u_103.pdf
 Filesize:  815.41 KB
 Downloaded:  754 Time(s)
inlifeindeath
PostPosted: Mon Jun 02, 2014 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
there's a red line after the caps which indicates you need to install a jumper. you can just use a clipped component lead or a piece of wire.
jooks
PostPosted: Mon Jun 02, 2014 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, but further down the line there is another jumper which is not connected. But I cant see why it should be connected either?
