A collection of circuits by Nicolas
Page 2 of 2 [36 Posts]
Goto page: Previous 1, 2
LeftyLogic
PostPosted: Mon Feb 11, 2013 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello everyone, this is my first post here, and I'd like to thank Nicolas for designing all these wonderful circuits! Very Happy I just finished soldering together the Super Simple VCO (My first DIY module) and it sounds fantastic! I'm starting off into Synth-DIY by putting together a simple modular system comprised mostly of modules found in this thread, and I'm loving it so far. Smile
Thanks a million for making all this information easily available!
Regards,
Seth
-minus-
PostPosted: Sat Mar 15, 2014 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Just adding the link to the simple but fun bleepy machine, before it gets buried in the catacombs:
http://electro-music.com/forum/topic-61208.html
civi
PostPosted: Tue Jun 03, 2014 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
nicolas, Awesome work and Thanks a lot for this valuable information and now I am busy with your circuits as I just finished the saw tooth oscillator and it worked well so now I am planning to make the VCO.
MJONES32
PostPosted: Sat Oct 03, 2015 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I did build the Super Simple V/Hz , I think pretty close to the schematic,
as described here
http://electro-music.com/forum/topic-34550.html
It sounds good, and the V/Hz is good but not spot on.....is there a tweak that any one can suggest to provide fine control ?
nicolas3141
PostPosted: Sun Nov 15, 2015 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Having a go at arduino tinkering - http://electro-music.com/forum/topic-65389.html
steved
PostPosted: Mon Nov 23, 2015 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
nicolas3141
Thanks you!
I am new to electronics, have been a synth nerd for 30 years-
Your posts are SO helpful!
I was working on finishing your VCF and planned to make an Arduino module next. Perfect timing of this post for me.
Project_2501
PostPosted: Wed May 09, 2018 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did Nicolas ever make a publish/compile a book of his simple diy synth designs from his class he was teaching. I would love to have a paper copy Smile, if there isn't any book, I'm already compiling my own notes/prints of nicolas designs so no worries.
J-chot
PostPosted: Tue Sep 25, 2018 2:48 pm    Post subject: stupid question Reply with quote  Mark this post and the followings unread
I feel like I should know the answer to this, especially after trying to find an answer myself with research, buuuut....
If I were to power a LM324n (for THESE specifically) with a Dual 12 v supply,
would I hook -12 to pin 11 and +12 to pin4?
J-chot
PostPosted: Tue Sep 25, 2018 4:55 pm    Post subject: Re: stupid question Reply with quote  Mark this post and the followings unread
ok, from context clues I think I figured out that Lm324 doesn't work on -12 power?
to use a TL074 instead?
help
PostPosted: Wed Sep 26, 2018 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
LM324 works fine with a dual 12V supply (yes, pins 4 & 11).
If the circuits will work on -/+ 12V depends on a coupe of things. If it is originally powered by -/+9V it should work fine
as long as there isn't anything directly derived from the power. Otherwise some values might have to be adjusted. For example
a reference voltage created wih a voltage divider between +9V/GND would produce a higher voltage if you'd use +12V/GND.
If the circuit is powered from a single +9V supply it could still work on -/+12V but it might need some more adjusting.
Often these circuits have a fake/virtual GND which you can then replace with an actual GND but it might need some other changes.
J-chot
PostPosted: Wed Sep 26, 2018 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Phenomenal. I got Magic Smoke the other day and I've been questioning everything since. I'll let you know when I successfully breadboard an op amp circuit on my new dual power supply!
