Black Overlay Transformation
Page 1 of 1 [4 Posts]
Helge Kautz
PostPosted: Tue Jun 27, 2017 12:38 am    Post subject: Black Overlay Transformation
Subject description: Transforming my Andromeda into a Black Galaxy :-)
Hey there,
I just applied the black overlay (made by Thomas Heck) to my Andromeda. I think it looks gorgeous:
http://imgur.com/a/4XBKq
Thomas' instructions said to stick the overlay on top of the original one, but I removed the original one completely instead, because it fits much better this way. I removed the residual glue with a rubber, because I didn't dare to use chemicals for fear of spilling into the PCBs.
Next thing on my "upgrade list" are wood sides. I already contacted a few carpenters with CNC machines. I hope I don't have to remove the upper PCB to attach the new wood sides -- it was difficult enough to remove the plastic sides without removing the PCB as well...
Helge
deleted user on request
PostPosted: Wed Jun 28, 2017 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great. I'll probably get around to installing mine this weekend. Lots of bloody work.
PostPosted: Tue Jul 25, 2017 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
When you say you removed the glue with "a rubber" what do you mean?
Helge Kautz
PostPosted: Fri Aug 04, 2017 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
It also works using just the fingers, but I got blisters on several fingers after an hour rubbing away at the glue. It's really extremely sticky. I tried using different materials -- tissue and plastic -- but that doesn't work at all. What did work was the rubber coating on the backside of a toothbrush stick. I worked myself through two toothbrush (-sticks). If this had not worked, I'd have bought a proper pencil eraser. So yes, I mean a pretty stiff rubber/eraser-like material.
Helge
